1993 Stalls out when coming to a stop
Old Apr 17, 2009 | 09:28 AM
classicidi's Avatar
Default 1993 Stalls out when coming to a stop
Ok guys any help is much appreciated. The truck in question is a 1993 w250 5 speed. The truck starts and runs great it even idles fine, however if you have the rpms up say 1000 or higher and you push the clutch in to come up to a light and let off the gas, the truck with drop way down and stumble then come back up to idle or it will just die all together. It starts right back up but it is a very irritating issue. The idle does seem to be a little high but i don't think that will affect it.
thanks for any help
Old Apr 17, 2009 | 09:41 AM
Whit's Avatar
Site Mascot
try cleaning the pre filter out
Fuel Pre-Filter Cleaning on Ram/Cummins
Old Apr 17, 2009 | 10:07 AM
classicidi's Avatar
my truck does not appear to have this it the location outlined in the article. is there one of these strainers above the fuel filter where the fuel heater is located on my truck?
Old Apr 17, 2009 | 10:50 AM
Rocky Mountain Texan's Avatar
my 97 12 valve had the same problems. i got the injectors cleaned, adjusted the timing, and then bumped up the idle and it runs fine now and now longer dies.
Old Apr 22, 2009 | 10:28 PM
classicidi's Avatar
when you say adjust the timing what exactly do you mean? IP timing or????
Old Apr 22, 2009 | 10:31 PM
94cummins12v's Avatar
advance it forward.
Jake12valve
May 10, 2015 11:57 PM
redjello
Apr 13, 2015 08:27 PM
Jan 22, 2015 10:10 AM
irishbmx
Nov 19, 2014 01:47 PM
