more fuel hard on pump?
Old Apr 17, 2009 | 07:17 AM
BAD ASS RAM's Avatar
Question more fuel hard on pump?
i've been told by a couple people that if you turn the pump up too much that it is hard on it,and it will eventually go bad.is there anything to this,or is it bullshit?is there anything you can do to one to shorten it's life?
Old Apr 17, 2009 | 08:24 AM
lobsterman04's Avatar
I, too have heard something along those lines and have a few buddies with 12v's that want em turned up a bit but are worried about hurting things. So lets get some clarification before i go tweaking things.
Old Apr 17, 2009 | 08:29 AM
AS YOU CAN SEE IN MY SIGNATURE I HAVE ALREADY,I JUST WONDERIN IF I SHOULD EXPECT TROUBLE.
Old Apr 17, 2009 | 09:17 AM
94 12valve's Avatar
as long as you get fuel to the p7100 it should be fine, if you don't keep goop fuel press thats when they start to blow up ... ask me how I know
Old Apr 17, 2009 | 09:44 AM
HOW MUCH PRESSURE IS IDEAL?
Old Apr 17, 2009 | 11:11 AM
94 12valve's Avatar
bosch says 17-22 at idle and 25-35 at 2500 rpm with no load on the motor. when I finish my engine build Im gonna run 40 psi all the time with my air dog 150
Old Apr 17, 2009 | 01:33 PM
xzaq103's Avatar
FormerVendor
"blow up"? Dave you talking about sticking a rack?
As for too much FP. Jamie Wood on here is running 40 PSI at idle and 80 at full throttle with no issue. Ive see dyno graphs of hp at 40 and hp at 80 on back to back runs they had 1 - 2 more hp.
Old Apr 17, 2009 | 02:27 PM
94 12valve's Avatar
no I ment blow up ... as in I removed the dv and was picking pecies of the #5 plunger out with a pair of needle nose pliers. I'm not 100% sure how it happened cuz I had no fp guage at the time but I think my fuel press was low and caused the plunger to heat up expand and blow up.
Old Apr 17, 2009 | 02:29 PM
OUCH!!
Old Apr 17, 2009 | 05:04 PM
94 12valve's Avatar
Originally Posted by BAD *** 1997 RAM 2500
OUCH!!
yep took it to a pump shop and the worker there said he never saw a pump go like mine did, I ended up buying a new rebuilt pump. this turned out to be a $1200 mistake that will NEVER happen to me agian
