preventing a problem before it happens
Old Apr 16, 2009 | 10:02 PM
oglejust's Avatar
Default preventing a problem before it happens
a guy at work that has a 98 12v cummins showed me that his exhaust manifold is shrinking and starting to make the bolt crooked, after seeing his 98 like that i opened the hood on my 94 and its way worse. i realize the only way to prevent this is w/ the ats 3 piece manifold, im gonna start saving for 1. also to the people that have installed the ats manifold whats the best way to take the old bolts out? i heard a ratchet but i also heard that its better to use a 3/8 impact. any1 know where i can get the best price on 1?
Old Apr 16, 2009 | 10:10 PM
Whit's Avatar
Site Mascot
here is some info on the HTT 3 piece unit
https://www.dieselbombers.com/5-9l-2...-manifold.html
Old Apr 17, 2009 | 05:47 PM
oglejust's Avatar
cool man thanks... wats ur advice on taking the old bolts out?
Old Apr 17, 2009 | 08:54 PM
Whit's Avatar
Site Mascot
just use a ratchet or a box end wrench....if it starts to hang up and gauld then go back in and then back out...work it ..........oh and use alot of good penetrating oil too, squirt it down the night b4
Old Apr 18, 2009 | 02:12 AM
akdiesel97's Avatar
I have my 3 piece manifold i was just waiting till the end of the work season before i install it, I heard if you warm up your truck then spray down all your bolts with some high quality lube while its still hot and just keep rotating around spraying your bolts with the lube till it stops working its way into the bolts they will come out pretty easy. but main thing is make sure you dont break the bolt cause your goina have a hell of a time getting it out if you do.
Old Apr 18, 2009 | 02:19 AM
KROIL...(probably the best penetrating oil on the market)
KanoLabs.com
burndiesel
10
Feb 7, 2023 01:15 AM
Jake9473
Jul 22, 2018 08:19 AM
jeremy01995
Sep 14, 2015 06:34 PM
Rabbitjbu
Jul 28, 2015 06:03 PM
Dadslb7
Dec 9, 2014 11:05 PM
