adjusting torsion bars
Old Apr 15, 2009 | 08:38 PM
dhardy1357's Avatar
Default adjusting torsion bars
im wanting to lower my torsion bars till the cv shafts are parallel but not quite sure what to do. anyone got pics of what to look for and what to adjust. i have some 305's on there now and dont want to have to downgrade to 285's when i lower it. is there a way to get around this?
Old Apr 15, 2009 | 08:49 PM
cashwheel's Avatar
Its pretty easy man, just follow the torsion bars back till they end in a crossmember, there you will see a porkchop looking piece at the end of the bar inside the crossmember, at the bottom is the adjusting screw. First decompress the "porkchop" with a C-clamp, enough to take the load off the adjusting screw, back it out the desired amount and take the clamp off. You will want to do this on a level surface, pref. concrete slab, measure each side from the ground to the fender, make sure they are the same, some will tell you to count your rotations and keep them the same, but it doesn't always come out right when you do it that way. If I had a chevy around I'd take some pics for you, sorry.
Old Apr 16, 2009 | 12:13 AM
2500HeavyDuty's Avatar
you really dont want to to try putting any kind of clamp on the tortion keys while the truck is still on the ground. theres alot of load built up in them torsion bars and even more when the truck is flat on the ground.
jack up the side you want to do first and make sure that the front tire is off the ground, and then you can use an 18mm socket and breaker bar to unscrew the adjusting bolt.
some people also hit the bolt with some spray paint and add washers all the way up to the paint mark to make sure the bolt goes back where they used to be before the lower the truck completly fo racing and sled pulling.
be sure to use antisize on the bolts too
Old Apr 16, 2009 | 12:27 AM
cashwheel's Avatar
Not to be a D*%k but yeah you do want to unload the keys, I've done literately hundreds of different trucks and that is the easiest and safest way to guarantee that the adj bolts wont strip.
Sorry about that, I thought I put jack the truck up in there, guess I'm the a&*h%$l
Old Apr 16, 2009 | 12:44 AM
wont worry bout it.
i adjust mine with out the tool because buying a 70+ torsion bar unloading tool to do the job right not every one wants to do. but it is safer that way and easier on the thread cause those bolts strip easy, too tight = broke
Old Apr 16, 2009 | 04:13 PM
dhardy1357's Avatar
ok thanks guys. is there any like kind of spacer or something so i dont have to get 285's. my 305's rub when the torsion bars or lowered
Old Apr 16, 2009 | 09:16 PM
use a really big hammer to fix that
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
rvlmeyer
Feb 15, 2015 03:36 PM
Cumminsfreak24
Jan 21, 2015 09:10 AM
carid
Oct 28, 2014 08:42 AM
