Smarty + Edge Juice
Old Apr 15, 2009 | 02:20 PM
rkadcock's Avatar
N.M. Bombers Director
Default Smarty + Edge Juice
I just bought my 07 5.9 Cummins and I've already got my smarty ordered but for a little more power down the road, would combining the smarty with an edge juice be a good combination? Is anyone running this setup? Is anyone running a smarty with another chip?
Old Apr 15, 2009 | 10:31 PM
Dieselhead Jake's Avatar
ive only heard people use just straight up smarty...
Old Apr 16, 2009 | 12:27 AM
mikew's Avatar
not sure about ur 07 but my 03 i can run the edge and smarty on even numbers. the edge advances timing and u shouldnt double add timing hense the even numbers on the smarty
Old Apr 16, 2009 | 01:48 AM
CumminsRig's Avatar
Yes you can run that setup a lot of people have done and like it. Like said above run the smarty on even #'s.
Old Apr 16, 2009 | 06:59 AM
AF1CUMMINS's Avatar
Another popular stack I've heard of especially with the common rail motors is the Smarty ans TST stack. Most guys I've read about makin 1000+ seemed to have that setup
Old Jun 22, 2009 | 04:10 PM
1badcummins's Avatar
my friend just put a hole in a piston stackin the two
Old Jun 22, 2009 | 04:41 PM
07redsled's Avatar
tst will not work on a 07 5.9 cummins but the quadzilla adrenaline is good too i hear
Old Jul 21, 2009 | 09:16 PM
firedodge36's Avatar
So What would you suggest if you were going to stack the 2? would you just get rid of the juice and keep the smarty? From what i heard you should run the smarty on a high setting when you are just driving down the road but you can use them for a quick drag...
Old Jul 21, 2009 | 09:23 PM
rkadcock's Avatar
If you're going to run both, you would use the edge for timing and you would keep the smarty on the even # settings. If you use both for timing then your more than likely going to put a whole through a piston... Until I get my CP3 taken care of I won't be able to even try stacking the two but my smarty by itself is purely amazing, I usely run in 3 or 5 (#3=60hp #5=90hp) and my truck gets it, and before my CP3 started dying #9 threw your head in the back of the seat...
Old Jul 21, 2009 | 09:49 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i got juice and smarty on 08 6.7. i just use edge for gauges.
