steering issue
Old Apr 15, 2009 | 08:12 AM
h8pvmnt's Avatar
Default steering issue
A friend is having trouble with his super duty & I thought somebody else might have had or heard of this before.
05 with the 6.0 and 91,000 mi. on it. If I pull over and turn the wheel lock to lock it gets better. It usually only does it after I first start driving it but lately it has started doing it after it has been on the road a little longer. I am pretty sure it's a fluid power issue and not mechanical. It will pull to the right and I have to fight to keep it somewhat straight then it is like the fluid pressure releases and it takes off to the left. If you were following me down the road you would swear I had a case of beer in me.
TIA, Ed
Old Apr 19, 2009 | 12:40 PM
2500HeavyDuty's Avatar
whats heppeneind with it
Old Apr 21, 2009 | 08:05 AM
h8pvmnt's Avatar
The popular thought is that it's a weak/damaged spring in the gear box or a sticking valve, bleeding pressure to one side. He's getting another gear box to try out.
Antwhite19
Aug 23, 2015 06:07 AM
ramrunner01
Jun 1, 2015 12:10 AM
Boostaddiction
May 4, 2015 06:28 AM
BubbaDT55
Apr 12, 2015 10:47 PM
sweetv8s10
Oct 7, 2014 09:47 PM
