installing injectors TOOLS NEEDED?
Old Apr 14, 2009 | 08:58 PM
will1am's Avatar
Default installing injectors TOOLS NEEDED?
i plan on installing injectors tommorow.it looks like i can get a wrench in there to take them out.What size deep socket will work?or is there a special 90 degree tool to take them out.
thanks
Old Apr 14, 2009 | 09:07 PM
94 12valve's Avatar
you will need a 10mm wrench for the fuel return, a 3/4" open end wrench for the fuel lines, and a 3/4" deep socket for the injector nut. you will also need some sort of pulling device to get them out, I thread a nut on top of the injector and jiggle it back and foward with a pair of vice grips till it pops out.
Old Apr 14, 2009 | 09:08 PM
diesel_tallent88's Avatar
15/16 deep socket
15/16 deep socket for injector nut
Last edited by diesel_tallent88; Apr 14, 2009 at 09:08 PM. Reason: Automerged Doublepost
Old Apr 14, 2009 | 09:10 PM
94 12valve's Avatar
Originally Posted by diesel_tallent88
15/16 deep socket
thats right typed the wrong size sorry man
Old Apr 15, 2009 | 12:39 AM
ykdave's Avatar
A piece of tubing and a wheel nut make for a cheap and easy injector puller. Slide the tube over the injector and tighten the nut onto the top of the injector, as the nut tightens up and hits the tube it pulls the injector up. Another option is to just thread the lugnut on and pry it up with a prybar.
Aside from the big nut, their is also a spring loaded ball that holds the injector in so they can be a bit of a PITA to pop out, but they will...
Old Apr 20, 2009 | 07:18 PM
djwhonda92's Avatar
ok guys, i am installing some injectors.. but i cant get the 15/16 down in there cuz the fuel lines are in the way
Old Apr 20, 2009 | 07:31 PM
06 DIESEL's Avatar
You have to remove the fuel lines to install injectors. I have done it without removing and with removing the lines and it is 100 times easier to do it with the lines off. Take them off as a whole unit, do nto take them apart.
Old Apr 20, 2009 | 07:33 PM
94cummins12v's Avatar
take the injector lines off from the pump to the injectors and take the return line off as well, when you put the injector in and press it down turn it clockwise till it stops, that will make it so the banjo bolts line up on the return lines
Renteria1217
19
Oct 13, 2015 01:36 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
