Starter Solenoid Fuse Blowing
Old Apr 12, 2009 | 11:05 PM
jimmyram01's Avatar
Default Starter Solenoid Fuse Blowing
starter solenoid fuse blowing causing motor to NOT CRANK over on a 2001 24 valve cummins. When i clean small wires on intake heater relay the fuse doesn't blow. So i replaced intake heater relay and cleaned all the wires and it was fine for a while, then it started happening again. Also sometimes the lift pump doesn't run. Could it be a starter problem or a lift pump problem?
Old Apr 13, 2009 | 02:36 AM
Uncle Bubba's Avatar
Just trying to remember the wiring I don't think the two of these could be related unless there is a common ground someplace.
When it doesn't crank try tapping the solenoid with a screwdriver or somethin just to see if it's stuck. If I were a bettin man though I would say the starter contacts are shot and that's not allowing the truck to start would be the more common issue.
You may also try jumpin the solenoid to see if it works then. Just use an insulated pair of pliers or a screwdriver and touch both bolts at the same time on the back side of the solenoid. Solenoids go bad but I've never heard of a bad one blowing the fuse. They just hang open or closed.
Be sure to fill in your signature so we know details about your truck.
Old Jun 26, 2009 | 04:57 PM
robbster's Avatar
Greetings from N. Colorado.
I'm having this same problem w/ my 2,000 5.9 Cummins. I removed the starter & it tested fine at Napa(it's a Napa replacement, new in 2006).In addition, the copper contacts looked good. My mechanic told me that the problem must be in the solenoid. Any ideas or thoughts?
Old Jun 26, 2009 | 06:17 PM
01greenmachine's Avatar
got the same problem ! but doesnt do it with my remote starter, so im thinking it might be the ignition switch ?
Old Jun 26, 2009 | 06:35 PM
DB Admin's Avatar
Banned
sounds like an epidemic
camp9
Mar 25, 2017 07:40 AM
klein444
Jun 20, 2015 11:48 PM
david.burger
May 30, 2015 08:25 AM
james2562
Feb 5, 2015 09:05 PM
nevadagramm
Oct 17, 2014 07:59 PM
