Tachometer hookup....
Old Apr 12, 2009 | 05:54 AM
LOGANSTANFORTH's Avatar
Default Tachometer hookup....
how do you hook one up on a 91.5-93 1st gen truck??? i know there is a article out there for it but i cant find it.....
Old Apr 12, 2009 | 09:51 AM
RSWORDS's Avatar
Logan tehre should be a plug hidden in teh column somewere.
Old Apr 12, 2009 | 09:54 AM
sidekick's Avatar
did you go to the pull yesterday bobby
Old Apr 12, 2009 | 10:11 AM
x2be1's Avatar
Default Tachometer hookup to SBEC for Gen I
The SBEC controller is where you will need to go to make your splice into the lead-out wire of pinout #43. This should be the Gray/Lt. Blue wire.
Old Apr 12, 2009 | 10:18 AM
i found out where its located....i also got my gauge pod question answered....and i finally got pictures of my new truck.....
Old Apr 12, 2009 | 10:21 AM
DB Admin's Avatar
Banned
Old Apr 12, 2009 | 10:24 AM
already posted....
Old Apr 12, 2009 | 05:24 PM
Richie O's Avatar
The 91.5's did not have the factory provisions for the tach. If your truck has the crank position sensor then you should have the factory plug. The 92 and 93's had them.
Here is a diagram I have.
Old Apr 13, 2009 | 04:42 AM
i got a 1993, i ordered the Glowshift digital tach, along with a bunch of other gauges for the truck yesterday.......here is all i got:
tach
tranny temp
fuel pressure
boost/pyrometer combo gauge
im also got a double and a single pillar pod and a steering column single pod, the ones from the 94+ trucks will work on the 93 models, maybe the 92's also......
Old Apr 13, 2009 | 09:15 PM
Richie O's Avatar
Will the gloshift tach read the 5 volt signal the computer puts out? Some of the tachs will not read that low of a voltage. As far as the column pod it will fit as long as it is a tilt wheel.
