wont start after plate
Old Apr 11, 2009 | 07:35 PM
bowtech's Avatar
Default wont start after plate
i slid the plate all the way to the front (towards the front bumper) and it wont start now. im goin to take it back apart and put it back tomorow mornin. wat would cause that?
Old Apr 11, 2009 | 08:06 PM
392hemix's Avatar
There should be no reason that the truck wont start due to the plate being full forward. your truck will run regardless, with or without the plate. I would check your shut off solinoid, if it is stuck on the off positoin then the truck will not start. try checking the function of that sucker, i bet you find your problem
Old Apr 11, 2009 | 09:50 PM
oglejust's Avatar
yeah i bet u bent the shut off solenoid
Old Apr 12, 2009 | 12:23 AM
89silverbullet's Avatar
or knocked a relay loose
Old Apr 12, 2009 | 12:28 AM
djwhonda92's Avatar
idk what the actual wire is but when i took my AFC apart to cut my fuel plate i unplugged this one thing that is in black tubing about a half inch thick, it made the housing more easily accessible. anyways i forgot to plug the male end back into the female end and my truck wouldnt even turn over. then i realized i forgot it, plugged it i and started her up..
Old Apr 12, 2009 | 01:19 AM
bowtech's Avatar
yea the plunger thing under it is bent
Old Apr 12, 2009 | 09:12 AM
392hemix's Avatar
well did you he get gauges?
Old Apr 13, 2009 | 11:04 AM
cummins2500's Avatar
yeah check your solinoid and if that is fine then hit the primer button a few times and it should start
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
