power door lock relay location?
Old Apr 11, 2009 | 05:49 PM
AF1CUMMINS's Avatar
Default power door lock relay location?
OK, my power locks aren't working and I bought the relay at Advance Auto. I can hear it clickin in the dash but can't find it to save my life. I looked in both fuse boxes cuz I knew there were some relays there but no dice. It's looking and sounding like half my damn dash is gonna have to come out just to change this thing. BUT i can't find it, soooooo ANY help would be REALLY appreciated. Pics would be even better. Thanx guys.
nobody has a clue?
Last edited by AF1CUMMINS; Apr 11, 2009 at 05:49 PM. Reason: Automerged Doublepost
Old Jul 2, 2009 | 03:37 PM
AF1CUMMINS's Avatar
bump
Old Jul 2, 2009 | 04:43 PM
DieselWeasel's Avatar
"Ohio Bombers" Director
There is no relay... Switches go directly to the "Central Timer Modual"
It is located...
"Under the driver side end of the instrument panel inboard of the instrument panel steering column opening. where it is secured with two screws to a stamped steel bracket that is integral to the instrument panel armature"
I can provide diagrams and pics if you like...
I assume this is for your 2001 2500 4x4?
is it VIN 6 or VIN 7??
Old Jul 2, 2009 | 07:36 PM
AF1CUMMINS's Avatar
3B7KF are the first few. I'm not sure what you mean by VIN 6 or VIN 7. But yes, it's the truck in my sig. Those pics would be greatly appreciated.
Old Jul 2, 2009 | 08:15 PM
stkdram55's Avatar
dont quote me on this but if the relay is clicking then chances are good the relay is fine and not stuck...and since the relay is clicking that means the switch is working to send power to the relay so i would be looking at the motor or whatever operates the locks...and im assuming you did check the fuses right
Old Jul 2, 2009 | 08:19 PM
The vin is for the 8th number... Tells if you have the HO 5.9 or not.
Here are the dwgs.
Old Jul 2, 2009 | 08:21 PM
Again there is no relay that is accesable... All that is in the control module.
Id agree of coarse thought that you have a bad ground, bad connection, bad motor, bad module or similar.
Old Jul 2, 2009 | 08:25 PM
stkdram55's Avatar
just throwing my 2 cents in...just a disclaimer i failed my first try at my electrical ASE
Old Jul 2, 2009 | 09:06 PM
Hey at least someone is trying to help people.. LOL!
I cheat tho.. I have ALLDATA !
Old Nov 5, 2014 | 07:58 AM
fcuica73's Avatar
Where at is this thing located??
I guess mine can be messed up, my truck is a 2006 Dodge Ram 5.9 and my power locks are not working, not with speed, remote or door control, could you please tell me where to find this part? My fuses are fine, thanks!
Here are the dwgs.
May 10, 2015 10:57 PM
Texasthb
Mar 4, 2015 08:20 AM
