fuel problem
Old Apr 10, 2009 | 08:24 PM
stevescummins's Avatar
Default fuel problem
I'm in the middle of installing a BD big line kit and holley blue pump because my stock lift pump started acting up. Can I just take the factory lift pump off and run the new line to the filter? If so should I wire the holley to the factory lift pump wiring or wire it to a 12 volt with the key on? Thanks for any help.
Old Apr 11, 2009 | 10:13 AM
dukeboy_318's Avatar
first of all, i would relocate the holley blue to the frame away from the motor, second, hook it to your factory lift pump wiring, third run the new line from the holley to the filter.
Old Apr 11, 2009 | 12:30 PM
I am mounting the holley right by the tank on the frame rail. Then go to the filter. Sounds good. They sent me a regulator with the kit. s it a good idea to put it in there after the holley or do I not need it?
Thanks for the help.
Old Apr 11, 2009 | 03:07 PM
Your not going to need the regulator but I do HIGHLY recommend putting a small inline filter in your fuel line BEFORE the Holley Pump. If you don't your Holley will not last very long because it will get junk caught in is screen.
Old Apr 11, 2009 | 04:05 PM
I will. I never gave that a thought. When the money gets better I'm going to put a fass or an airdog on it. Thanks for the help.
Old Apr 11, 2009 | 04:53 PM
redneck_cummins's Avatar
Default Airdog 100
I recommend the Airdog 100 when u get the money. Very reliable I never see more than 20psi and no lower than 15psi . Just my .02 cents
burndiesel
10
Feb 7, 2023 01:15 AM
Dbleo351
Nov 20, 2016 09:34 AM
stevew970
Jeep Liberty
Aug 31, 2015 07:56 AM
moneypitk5
Feb 12, 2015 11:01 AM
Colby cummins
Nov 16, 2014 01:18 PM
