03 cummins wont start
Old Apr 10, 2009 | 04:34 PM
pepper33's Avatar
Default 03 cummins wont start
I have taken my truck to lots of shops and had lots of parts replaced and it still wont start. it will push start, start with starting fluid, or get this when u replace the fuel filter? (once) After it starts it runs great, lots of power not much smoke and gets good mileage. any sugestions.
Old Apr 10, 2009 | 05:17 PM
mikew's Avatar
i would say ur lift pump is going or ur getting ready to need injectors i have an 03 cummins with 133,000 miles it cranked like heck changed fuel filter fired up and ran good u could bump start it it would start and run good then it got worse had to give it a little shot of either fired up ran good people said if u tack it up quick and leave off throttle the rpms will hang their for a second it didnt do that. ran it a little while longer then the rpms stayed up there took it to the shop and they said i need injectors.
how many miles do u have on it i was told the stock injectors are only good for about 140,000 miles
Old Apr 10, 2009 | 06:03 PM
pepper33's Avatar
it starter doin this at about 90k, it has 160k on it now
Old Apr 10, 2009 | 06:12 PM
mikew's Avatar
wow that beats the heck out of me. i read ur post and thought this sounds familiar. some of the seasoned guys will probally b able to help u out better. what all have u had replaced
Old Apr 10, 2009 | 07:56 PM
Camotanker's Avatar
what parts have you replaced already?
Old Apr 10, 2009 | 08:09 PM
pepper33's Avatar
replaced fuel pump lift pump injectors batteries fuel sensors and some kinda relay and had the starter tested. the last place told me it was a grimlin whatever the hell that means
Old Apr 11, 2009 | 12:40 PM
mikew's Avatar
is ur truck stock
Old Apr 11, 2009 | 01:59 PM
pepper33's Avatar
yep nothin fancy
I was wanting to try that injector test where u cap each line and try to start it, I was reading about it on here. if anyone knows how to get some detailed instructions on how to do that let me know. I'm no machanic but it didn't seem that hard and I'm tired of paying people to not fix my truck.
Old Apr 11, 2009 | 02:09 PM
mikew's Avatar
r u talking about capping the fuel rail Old 07-19-2008, 06:17 PM
06 DIESEL's Avatar
06 DIESEL 06 DIESEL is online now
06 DIESEL is ready for TS
Donation Level 5
award
My Diesel: 2006 CTD 6-speed
Casino Cash: $221070
Send a message via AIM to 06 DIESEL
Talking Capping A Fuel Rail
To cap a fuel rail on a CR you need a 19mm wrench, a tap, and a set screw. (not sure on the size of the tap or set screw)
Here is the pressure relief valve and banjo bolt on a 06 in the truck
Here is the pressure relief valve on a 05 out of the truck
Here is the banjo bolt
Remove out the banjo bolt
Tap the banjo bolt
Put set screw in the banjo bolt
Reinstall banjo bolt
Now your relief valve can blow off but no pressure can get out. **CAUTION** Doing this can cause harm to the fuel system. This relief was installed by Chrysler for a reason, keep that in mind.
woops i coppied and pasted thought the pics would come up. search this form ( capping a fuel rail) its very easy to do takes 5 minutes
if ur pressure relif valve poped that would probally help it
Old Apr 11, 2009 | 03:06 PM
pepper33's Avatar
thanks, I also read about how u can unhook each fuel line one at a time and cap it somehow, once one is capped then you try to start it. if it doesn't start u move to the next one then if u cap one and it starts that's your bad injector? does that sound right?
