Engine Light
Old Apr 10, 2009 | 10:21 AM
NickH's Avatar
Default Engine Light
2005 CTD 68,000 miles.
Just recently cleaned engine compartment and started truck when finished had no problems. Truck sat for 4 days without being started and now the engine light is on and it runs very ruff. Any suggestions where to start checking? Thanks for all input.
Old Apr 10, 2009 | 10:26 AM
wildbill's Avatar
Check all the injector harness connections. Use some electronic contact cleaner to aid in moisture removal.
Old Apr 10, 2009 | 10:43 AM
cumminscontrol's Avatar
cycle the key switch 3 times on and off and see what code(s) u get....theres a Check Engine Code list posted on this site with all the codes and what they are.
Old Apr 10, 2009 | 11:16 AM
NickH's Avatar
P0192 Fuel Rail Pressure Sensor Circuit Low Input
Going to unplug it and clean with contact cleaner and try again.
Old Apr 10, 2009 | 12:12 PM
stkdram55's Avatar
yeah put some di-electric grease on it too, that will help it from happening again
Old Apr 10, 2009 | 12:19 PM
NickH's Avatar
will it hurt anything if I drive it to get some contact cleaner? The can I had is empty.
Old Apr 10, 2009 | 12:24 PM
stkdram55's Avatar
shouldnt, its just saying the rail pressure is too low i think...as long as it isnt low you should be fine. You might just unplug it and blow it out with some air and then hook it back up and clear the codes and it might be good to go
Old Apr 10, 2009 | 06:17 PM
NickH's Avatar
Had water in electrical connections.
Is there a way I can reset the code without taking in to the dealer?
Unplugged injector harness connections and fuel rail pressure sensor, cleaned with electronic contact cleaner dried them all out with air compressor.
Thought I had it taken care of, but still a no go.
Runs perfect for about a minute then it will breakup, idles up high, then down and will run for about 5-15 minutes then die. I leave it turned off for a minute try to start again and it repeats itself. Also it is blowing white smoke instead of black smoke.
The engine code P0192 Fuel Rail Pressure Sensor condition has 4 probable causes
1-Fuel pressure low-fuel pump defective
2-Fuel pressure regulator defective
3-Replace fuel filter
4-Replace Fuel Rail Pressure sensor (HOLY SMOKE $573.00 at dealer!)
Thinking about trying the filter just because it is inexpensive thing in the process of elimination. Any thoughts?
Thanks for all the help!
Old Apr 11, 2009 | 08:50 AM
take it to autozone...they have a scanner they can clear codes and lights with...my buddies 06 3500 did that they other day with the same code...i cleared the code on the dash inside the truck for him by cycling the key switch, but the light stayed on...so we had to go to town anyway, and dropped by autozone and they cleared the light...its been a month and it hadnt came back..my 04.5 threw that same code up intermittently also....our trucks were runnin fine tho, think its just a glitch somewhere...damn, 573.00 for a sensor is damn crazy...if it was me, id start with the cheap things first and do the process of elimination...hell if it dont work, atleast u got a new fuel filter on there
Old Apr 13, 2009 | 08:49 PM
NickH's Avatar
Got my truck back from dealer today.
They replaced the Fuel Rail Pressure Sensor.
Thank goodness it was still under warranty!
THANKS TO EVERYONE FOR THE HELP!!!!!!
