fuel cutoff relay:how to check
my selenoid to cut off feul is not lifting up to help turn the feul supply on.
i have read about checking the wiring harness but am a bit new to electronics diognostics.
i have a volt meter....how do i check the relay?continuity,amperage?do i ground out and look for that from the relay or harness?right off the selenoid or relay?
thanks
thanks
Wellllll, mine went bad. it actuallly wouldnt shut off when thekey was turned off. Went to my local Cummins shop, they metered it while i watched. they gave me a chice, new Cummins part,or an aftermarket one.its spendy, but the Cummins one is much more stout>
Good place to find a new one or you could make a fuel shut off pull cable.
LarryB's Dodge starting problems solved here.
A good discussion here that may help you
No power to Shut Off Solenoid? - Dodge Diesel - Diesel Truck Resource Forums
Good Luck
Ross
Good Luck
Ross
If you want to ghetto check it, you can put constant 12 volts to the red wire then just touch the white one. The red is "hold" that holds the solenoid open, white is "pop". Just make sure you don't put constant power to the white wire or you'll fry it. White pulls a lot of amperage to pop it open, red pulls just enough to hold it open.
RatsMC
May 4, 2015 05:25 PM
