help asap!
Old Apr 5, 2009 | 09:20 PM
navalseabee's Avatar
Default help asap!
i bought a new clutch for my truck, a rhio pac ceramic unit at the local truck store. (part number05-092-sr300). i took out my old clutch and installed the new one, all seemed to be fine everything was normal. i got her all put together and there is no pressure on the pedal. the clutch doesn't dis engage at all. im certain that the clutch plate is in correctly. i believe my problem to be the slave cylinder. any help? i need help fast i need to get to work next week
the clutch pedal does have some resistance , but its all spongey like theres air in the lines. theres no bleeder so i tried to bench bleed it but it doesn't help
oh....one more thing, the directions in the clutch kit mentioned something about gett the counter bore of the flywheel bored bigger, but when i test fitted the plate it fit fine nice and flush against the flywheel.im lost and in a bad spot
bump
Last edited by navalseabee; Apr 5, 2009 at 09:20 PM. Reason: Automerged Doublepost
Old Apr 5, 2009 | 09:22 PM
RSWORDS's Avatar
Bleed it again. Sounds like tehre is air in it somewere still.
Old Apr 5, 2009 | 09:55 PM
where can i get a new slave/master cylinder...a better heavy duty one in a hurry
Old Apr 5, 2009 | 10:14 PM
We can get ya a Valair Upgraded Hyd. Kit
Old Apr 5, 2009 | 10:38 PM
Tweaker727's Avatar
Have you tried doing a vacuum bleed setup ?
Take the top off of the clutch master, and hook up a vacuum pump to the bleeder on the slave, and let it draw plenty of fluid from top down,
Otherwise, i have no idea
But i have ONCE in my life time seen the firewall RIPPED, when you push the clutch in, it would just push the firewall in and not give all the pressure to the clutch master.
We spend almost $300 trying to figure this out, and all it took was 3-4 good tack welds to fix.
Nick
Old Apr 6, 2009 | 07:33 AM
BAD ASS RAM's Avatar
i say bleed the **** out of it!it takes alot longer than brakes you'll think you're never gonna get it.
Old Apr 6, 2009 | 11:42 AM
gone ropin's Avatar
bleed it, do not pump it up to bleed, push to floor and bleed let it up and do again ,it sucks, if you have a vacuum bleeder try that you can do it it just a pain in the ****,
Old Apr 6, 2009 | 06:32 PM
well,i took off the slave to check it out and the seals are all messed up. So i bought the heavy duty South Bend unit,
GT_Eleanor
Aug 25, 2015 09:35 AM
willis964x4
9
Aug 22, 2015 12:21 PM
jeremiah1
Jun 21, 2015 06:45 AM
canigeta727
Mar 18, 2015 05:00 PM
yfzrunner
Feb 7, 2015 10:52 PM
