EGT gauge on 6.9/7.3?
Old Apr 5, 2009 | 05:58 PM
FarmDiesel's Avatar
Default EGT gauge on 6.9/7.3?
I have read many posts about turning up an injection pump, and all of them reccomend installing an EGT gauge. How is it one goes about doing that?
Old Apr 7, 2009 | 01:25 AM
jnicewan's Avatar
i put mine in the drivers side rear of manifold, there are raised humps on the manifold right at the exhaust outlets. i put mine in the rear one. i had to cut a drill bit down and used a 90 degree drill. other than making a custom bit it was easy. the hump i was talking about is a good spot because there is more metal for threads and also a flat spot for mounting. its a real easy step to do if you had the manifold or engine out.
Old Apr 7, 2009 | 09:19 PM
FarmDiesel's Avatar
Cool, thanks. What kind of gauge did you get? Any suggestions on gauge or sender or whatever?
Old Apr 8, 2009 | 01:40 AM
jnicewan's Avatar
i like the "issro" guages, they are easy to read and a pretty close match to what the factory guages look like. autometers, dipricol... a cool thing about isspro is they a option to get a color/warning type face. just besure to order the pre-turbo type.
ISSPRO Product Categories
Old Apr 8, 2009 | 02:48 AM
FarmDiesel's Avatar
Thanks. By the way, whats a safe operating temperature, as well as the maximum you can safely turn up the pump?
Old Apr 10, 2009 | 02:03 AM
jnicewan's Avatar
i think most would agree to stay under 1200 degrees. i set my pump up so when i pull a trailer up a hill floored it wont go over 1100 or so. i would rather drive the truck than have to stare at the egt and start backing off the fuel. it generally runs in the 600-900 range normal drive/accel, idles around 300. over 900 under heavy throttle.
Steve123
Sep 28, 2015 02:36 PM
TurboBoy6.5
Apr 12, 2015 11:22 PM
Brappp306
Mar 29, 2015 08:54 PM
MrCat4974
Mar 23, 2015 11:30 PM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
