pos ve pump
Old Apr 4, 2009 | 03:01 PM
Albert R's Avatar
Default pos ve pump
well i just had the pump off n i just had to put a new fulcrum lever (govoner assembly) i think its calld where the full power screw push's up agins well n the idle spring n new pistin springs in the head off the pump well now it wont start only wen i spry starting fluid into the turbo.....????...
i dont get how it ran with all the brokin n wen i buy new stuff to fix it it can run right..
well all the injecter lines are off n wen we spry starting fluid we get fule come in out but with out it nothin comes out all the air has to be out the lines cuz theres fule in the pump n the filter....some 1 help m over this pump
and i took out the plunger on the shutoff solenoid to see and still no fuel
Old Apr 5, 2009 | 01:12 PM
LOGANSTANFORTH's Avatar
it sounds like the pump isnt putting out enough pressure to pop the injectors....
Old Apr 5, 2009 | 01:45 PM
RSWORDS's Avatar
did you index the throttle arm correct when you put it back on?
Old Apr 5, 2009 | 01:47 PM
ITS A FIRST GEN DODGE, I WOULD WORRY MORE ABOUT IT IF SOMETHING WASNT BROKEN.......ive got 3 1st gens.....
Old Apr 5, 2009 | 01:58 PM
Albert R's Avatar
YEA N STILL WONT START evan if its full throttle or not still dont wana star or stumble
Old Apr 7, 2009 | 08:07 PM
Albert R's Avatar
what els could it be any 1 kno?
Old Apr 9, 2009 | 12:52 PM
Albert R's Avatar
how much?
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
Renteria1217
Apr 16, 2015 11:38 PM
B.k. Smith
10
Jan 7, 2015 02:29 PM
