Debadging ?
Old Apr 4, 2009 | 12:08 AM
JTProuhet's Avatar
Default Debadging ?
I am in the process of debadging my 04.5 I started on the tailgate since it already looks like crap since I put a big honkin dent in it.. I worked on it for about 2 hours and only got the SLT 4x4 heavy duty and the D off... I have read where it took guys a half hour to do the whole truck..... How do they do it so fast.. I tried PB blaster, JD all purpose lube and goo gone... Goo gone worked the best of the 3 but it is taking FOREVER.. I was also using a heat gun... I want to also do the door molding but dam those are going to take even longer... What works the best for getting the double sided tape off.. I am going to try fishing line to get the other emblems off since I tried floss and a piece of very small wire and ended up just heating them up and prying them off with a plastic screwdriver.. Someone please tell me how to get it done faster.. I don't want it to be a whole day project.... Thanks
Old Apr 4, 2009 | 12:10 AM
2500HeavyDuty's Avatar
i did my whole truck in 30 mins. i used a pin stripe wheel fishing line and a heat gun.
and for the trim moldings i used my hands, hurt my fingers so bad but its only pain
Old Apr 4, 2009 | 12:14 AM
mrsunk's Avatar
I wanted to do my door moldings to but did not know if it was just held on with the double sided tape or if it had tape and clips holding it on. Did not want to take it off and then have holes down the side of the truck. I also am in the same boat took off 4x4 and heavy duty and took a couple hours
Old Apr 4, 2009 | 12:27 AM
you can use a hair dryer, it don get too hot, just hot enough though to heat up the glue, and eat through it with fishing line. some people use goo gone, i personally never used it
Old Apr 4, 2009 | 07:04 AM
JTProuhet's Avatar
Goo gone doesn't work very fast... What is a pin stripe wheel? And where do I get one... My hands are hurting from scrubbing so hard
Old Apr 4, 2009 | 08:25 AM
05cumminsdrw's Avatar
me and mt brother did his 04 last year with heat gun and fishing line worked great took about an hour to do the hole truck going to be doing mine soon as soon as the weather breaks
Old Apr 4, 2009 | 08:42 AM
JTProuhet's Avatar
How did u get the adhesive off???? That is the hardest part..
Old Apr 4, 2009 | 11:27 AM
i heard they might have them at napa, i borrowed mine from a shop
https://www.dieselbombers.com/diesel...ipe-wheel.html
Old Apr 4, 2009 | 12:34 PM
WD-40 or some Goo-Gone also works very well.
Old Apr 4, 2009 | 01:21 PM
JTProuhet's Avatar
alright i called oreillys and they do have a eraser wheel... regularly 36.99, my works cost......... $25.80 .... hopefully it works as fast as you all say it does...
