converter or not
Old Apr 2, 2009 | 06:49 PM
richie waddell's Avatar
Default converter or not
come on guys let me know should i keep my catalatyic converter or not i have upgraded to a 4' banks monster exhaust and my gas milage has went to the pits will getting rid of the converter help
Old Apr 2, 2009 | 09:25 PM
RSWORDS's Avatar
Has your milage gone down because you like to hear that pipe sing?
That was my problem.
Old Apr 2, 2009 | 09:46 PM
know it has nothing to do with my lead foot my wife can drive it she is alot easier on it than i am and it is still not as good as it was before
Old Apr 2, 2009 | 09:48 PM
wildbill's Avatar
Mileage might come up, depending how plugged the converter is.
Old Apr 2, 2009 | 10:03 PM
am i better off just gutting what i got or buying a delete pipe
Old Apr 2, 2009 | 10:12 PM
wildbill's Avatar
Keep the converter. It will help hold some back pressure. Which is needed with a stock truck.
Old Apr 3, 2009 | 11:17 AM
cerberus60's Avatar
You didn't upgrade the exhaust as the stocker was laready 4". If your mileage went down something else happened to cause it.
A TC will help some but it won't cure other problems.
Old Apr 4, 2009 | 08:52 AM
any suggestions on what might of caused my milage to go down
Old Apr 9, 2009 | 03:34 PM
MegaMan's Avatar
My converter is MIA. I don't like the thought of the converter getting sooted up & causing problems so I deleted. I installed a 5" turbo back, lost some bottom end but mileage stayed the same. Plugged in a little Quadzilla module & got my bottom end back. I agree with RSWORDS; my mileage was worse right after I put my system on cuz I could actually hear it & stayed in it a little more.
You got a BHAF? Since your exhaust system is slightly better flowing you'll need a little more air coming in; that might help your mileage a little.
O.k., I'm stupid. I didn't read enough. I finally looked at your sig. So you have BHAF & intake so that must not be it. How much did your mileage drop?
Old Apr 12, 2009 | 09:41 PM
a couple of miles to the gallon according to the read out on the overhead computer
