Injector Spray Pattern
Old Mar 31, 2009 | 11:44 PM
bowtech's Avatar
Default Injector Spray Pattern
wat is the stock specs? i got some injectors with 155 im not sure is that the spray pattern or wat?
Old Apr 2, 2009 | 01:58 PM
xzaq103's Avatar
FormerVendor
Yeah it is sorta. Thats spray angle i do belive. 155* is what came in the first gens 2nd gens had 145. or at least the 12 valves did. 155 is also what the marine injectors are at. How many holes do they have? What years are they for?
Old Apr 2, 2009 | 02:09 PM
Look at the big brain on xzaq103...
Old Apr 2, 2009 | 10:19 PM
xzaq103's Avatar
FormerVendor
I wouldnt go that far MR Evil....
Old Apr 3, 2009 | 07:14 PM
bowtech's Avatar
they are for my 94 cummins they have four holes
Old Apr 11, 2009 | 12:41 AM
xzaq103's Avatar
FormerVendor
Im not 100% sure if 160 and 175s had 4 or 5 hole but I do know that marine 300 and 330s are 4 hole. Have you tried them? They will work but will smoke a little more than they should and make more heat than they should. Marines are a goodcheap injector if your making power on the cheap but for a little bit more you can get 145 spray. Honestly I would rather have 215s over 300s or 330s
