3/31/2009 - Today's Daily Special
Adam's Buttery Wax, Revive Polish, and Swirl and Haze Remover!
Please click on the link below for special pricing:
Adam's Daily Special!
Adam's Swirl and Haze Remover, Revive Polish, and Buttery Wax!
For a limited time receive a HUGE savings on this trio of shine! Everything you need to keep the exterior of your vehicle shining like a show piece!
Adam's Swirl & Haze Remover Car Polish
Gently massage swirl marks, oxidation, fine blemishes and hazy paint back to gleaming perfection with Adam's Swirl & Haze Remover Car Polish. It's your dual-action car polisher's new best friend!
Oh, those stubborn swirl marks! You can polish and polish and still they don't seem to go away.
Adam's has the cure, it's Adam's Swirl & Haze Remover Car Polish. When used with Adam's Swirl Killer Foam Pad (orange), you're got a swirl, haze, and fine scratch removal solution that can't be beat. Guaranteed!
Unlike traditional over the counter car polishes, Adam's Swirl & Haze Remover Car Polish uses premium alumina abrasives that are finer and work longer. The result is a car polish that gently massages swirl marks away, rather than abrasively cutting them away and leaving a dulled finish.
Adam's Swirl & Haze Remover Car Polish is formulated for use with professional grade dual-action car polishers, like the Porter Cable 7424. Dual-action car polishers operate at very high speeds (up to 6,000 oscillations per second), but the pad throw is very short. This requires the polish to be formulated with superior lubrication so the polish can be worked longer without drying out or scouring your car's paint.
Adam's Swirl & Haze Remover Car Polish is forgiving enough for a novice, yet it creates crystal clear paint finish that will please even the most seasoned professionals. Find out just how easy swirl removal and a high gloss finish can be with Adam's Swirl & Haze Remover Car Polish. For the ultimate show car finish, follow swirl removal with Adam's Fine Machine Polish, and take your paint gloss to a whole new level. Guaranteed!
TIP: Adam's Swirl & Haze Remover Car Polish can be applied by hand or dual-action polisher (recommended). When applied by machine, use in conjunction with Adam's Swirl Killer Foam Pad (orange).
TIP: Adam's Swirl & Haze Remover Car Polish is concentrated. Use only 5-6 pea-size dabs at a time on your pad. Work in well until the polish film is nearly gone. Do not work the polish until dry, as this may cause hazing.
TIP: When using Adam's Swirl & Haze Remover Car Polish followed by Adam's Fine Machine Polish, you can save a step by applying Adam's Fine Machine Polish directly over the polish film left by Adam's Swirl & Haze Remover Car Polish. It's faster and easier!
16 oz. Bottle.
Adam's Revive Prewax Cleaner Polish
Adam's Revive Prewax Cleaner Polish increases your paint's depth, shine and clarity while removing mild oxidation and smoothing away fine swirl marks. Works by hand or dual-action polisher!
Adam's Revive Prewax Cleaner Polish is a non-corrective paint polish that's formulated to keep paint in perfect or near perfect condition shining bright without harsh abrasives. Use Reveive Polish after removing bonded contamination with Adam's Detail Clay.
Adam's Revive Polish cleans deep into your paint's microscopic pores, making your clearcoat as clear as it can possibly be. At the same time, Reveive's ultra fine polishes round the hard edges of fine swirl marks and other imperfections, diminishing their appearance. As it works, Adam's Revive Polish wets the paint with essential oils, making your car's finish darker, rich and radiant.
Adam's Revive Prewax Cleaner Polish is easy to apply by hand or dual-action car polisher (Porter Cable 7424). By hand, use apply Adam's Revive Polish with an Adam's Wax & Dressing Foam Applicator. If you need a little more scrubbing and polishing power to remove visible oxidation and swirl marks, apply using an Adam's Microfiber Applicator Pad. By dual-action polisher, we recommend using Adam's White Polishing Pad at a machine speed setting between 3 and 5.
After polishing with Adam's Revive, your car is ready for your favorite wax. Select Adam's Buttery Wax for hand application or Adam's Machine SuperWax for machine application.
Don't have time to wax? Apply Adam's Brilliant Spray Glaze in 15 minutes or less! It shines and protects your paint, chrome and glass like nothing else you've ever tried.
16 oz. Bottle.
Adam's Buttery Car Wax
Waxing your car should be a joy, not a chore. Enjoy waxing your car again with Adam's Buttery Car Wax. Buttery smooth application and a high gloss Carnauba car wax shine!
Somewhere along the way, other car wax products became difficult. Apply a coat or this, a layer of that, they say. What a chore!
At Adam's Polishes, we believe that simple is always better. That's why we made Adam's Buttery Car Wax so simple and easy to apply in the shade, sun, hot or cold. It really doesn't matter how or where your apply it, Adam's Buttery Car Wax is super easy, so you can enjoy waxing your car again.
If simple car wax application were the only measure of a great car wax, making a premium product would be easy. Fact is, your car wax also needs to make your car shine while protecting it from the elements. Adam's Butter Car Wax delivers here, too.
Made using a modern blend of polymers for strength and high grade Carnauba wax for beauty, Adam's Butter Car Wax sacrifices nothing. Guaranteed! Plus, Adam's Buttery Car Wax never stains trim or rubber with an ugly white residue. That's because Adam's Buttery Car Wax is a pure car wax without abrasive powders or cleaners.
Adam's Buttery Car Wax is easy to apply with an Adam's Wax & Dressing Foam Applicator. Use sparingly, as a little goes a long way. A typical application requires less than an ounce of product.
16 oz. Bottle.
16 oz. Bottle.
16 oz. Bottle.
16 oz. Bottle.
Jan 20, 2015 03:01 AM
Dec 5, 2014 11:50 AM
Nov 12, 2014 08:10 AM
