93 first gen auto trans info
Old Mar 30, 2009 | 03:03 PM
The_fabricator's Avatar
Default 93 first gen auto trans info
I'm wondering if I can bypass the comp and use pressure switches instead
Old Mar 30, 2009 | 07:54 PM
The_Head's Avatar
IF you are talking about getting it to shift into overdrive, I believe the answer is yes.
Old Mar 30, 2009 | 08:26 PM
so all the comp dose is shift it in to over drive?
Old Apr 3, 2009 | 04:16 PM
The_Head's Avatar
Yep, as far as I know.
The PCM controls OD, alternator charging, and the speedometer needle.
Old Apr 4, 2009 | 03:05 AM
sweet thanks for the help
Old Apr 4, 2009 | 12:13 PM
The_Head's Avatar
You're welcome.
from one n00b to another.
Old Apr 5, 2009 | 02:05 PM
Diesel Nut's Avatar
If you want to bypass the PCM, you will need to remove the OD control wire from the PCM wire harness or cut it at some point, then splice it into a switch. You want to splice the black wire on the transmission, and run the switch to ground. 12v is supplied to the OD solenoid and the solenoid is engaged by grounding out the circuit. THis also works if your transmission will not shift into OD automatically from a bad PCm or TPS.
Old Apr 9, 2009 | 01:02 AM
thanks for the help you guys rock
DieselDan_5.9
Jul 30, 2015 07:05 AM
Beau_Jacques
Jun 26, 2015 12:17 PM
kydieseltech
May 28, 2015 05:00 AM
apehangerjoe
Mar 26, 2015 03:01 AM
countryboy040993
22
Nov 12, 2014 11:25 AM
