rack plug
Old Mar 29, 2009 | 08:53 AM
392hemix's Avatar
Default rack plug
how good of an investment is a rack plug, does it really make your truck fuel harder? any noticable differnce?....
Old Mar 29, 2009 | 03:28 PM
94 12valve's Avatar
if you have a 160, 175 or 180 pump it is a great investment as long as you have the mods to take advantage of it. A 0, deep 100 or no plate and a moded afc is what you need to make it work
and yes if fuels way harder, you get an extra 2mm of rack travel
Last edited by 94 12valve; Mar 29, 2009 at 03:28 PM. Reason: Automerged Doublepost
Old Mar 30, 2009 | 09:09 PM
392hemix's Avatar
Hmmm, well then i might have to dabble with the idea of getting one. BTW what do you mean by a "DEEP 100 plate" i just got a custom 100 from whitmore
Old Mar 30, 2009 | 11:06 PM
collinscummins's Avatar
Whats the difference between a 100 plate and a zero plate? I was looking into doing the rack plug too actually so this is good news.
Old Mar 30, 2009 | 11:14 PM
392hemix's Avatar
the difference is full fuel @ all time with the 0 plate. the 100 will give you better driveability, and the fuel of the 0 @ full throttel. i am going with the 100 because i don't want to blow my trans and i have not had a diesl long enough to trust my self with the skinny pedal
Old Mar 30, 2009 | 11:23 PM
djwhonda92's Avatar
ya i'm running the 100 and dont worry, it still blows smoke when you lug it into overdrive it pours out!!! anyways what is a rack plug??
Old Mar 30, 2009 | 11:26 PM
Go to Diesel Performance Parts Power Chips Diesel Exhaust Intake Performance Products look it up in the 94-98 12valve section you should be able to find it pretty easily. Like it says above it just allows more movement of the rack inside your pump.
Old Mar 30, 2009 | 11:34 PM
xzaq103's Avatar
FormerVendor
Its about 30hp with the right mods.
A #100 has a foot so you dont have to adjust the gov arm to run it at FF plus its not as hard on parts.
Old Mar 31, 2009 | 10:24 PM
gone ropin's Avatar
try installing a higher pressure fuel regulator valve, i up graded to a 40 psi one and noticed a world of diffrence
Metz1234
Mar 3, 2016 10:20 PM
94chevy6.5
Tech Article Submission
Jun 16, 2015 12:45 AM
ajwright64
Feb 4, 2015 09:36 PM
norcal6.5
Dec 7, 2014 07:04 PM
wpg6.5
Nov 19, 2014 04:56 PM
