6sp
well first im assuming your talking about a 6 spd manual tranny, and yes it should bolt up to the engine, now the t-case im not sure on...and you will also have to get your driveshafts re cut because the 6 spd is alot bigger than a 5 spd
You need a 6speed flywheel and clutch also.
Front shaft will have to be lengthened and the rear shortened.
My son put a a late model 6 speed (G56) manual in his 95. Needed to modify the drive shafts. Also need new flywheel clutch, pressure plate. He bought the whole clutch setup from South Bend. Also need a wide cross member which has to be modified (lowered) to accommodate the size of the six speed. I think he also had to bend the shifter lever some.
