VP44 or What
Old Mar 28, 2009 | 07:11 PM
JLWelding's Avatar
Default VP44 or What
Been haveing problems for a long time. The eng. surges eradict but only slightly. When at hwy speed say 65 you let off and rmp get to about 1500 then put it in nuteral rpm drop quick to about 700 then pick back up,if A/C is on it almost dies. No white smoke no black smoke fuel mileage is normal. And when you rev up the eng. then it starts droping it has a little rev up right before idle. I here common rail motors do this, why would a vp motor do this. I changed the inj. to 75 hp and it started this so I had rv 275's rebuilt and put them back in and still the same no change.I dont no if this means anything but rpm gauge bounces a little at idle. Also I loosen inj. lines so there would not be any problem with cross over tubes lineing up with inj. and retighten. I always wash eng. where inj. lines go into head so there is no dirt getting in there. I dont know how much more I can do.
Thanks for your help.
Joe
Old Mar 28, 2009 | 07:52 PM
Whats your fuel pressure?
Old Mar 28, 2009 | 08:00 PM
dukeboy_318's Avatar
try un-hooking your edge box and see if that helps
Old Mar 28, 2009 | 08:11 PM
JLWelding's Avatar
Fuel pressure is 15 lbs. I disconnected Edge and no change.
Old Mar 29, 2009 | 09:28 AM
Mopar1973Man's Avatar
Well JL Welding you sure do get around...
Believe it or not I've talked to him quite abit about this problem but I've run my typical stuff and his bases have been covered.
Old Mar 29, 2009 | 03:58 PM
Rollin Coal's Avatar
if the apps has been adjusted, id start saving for a new vp
Old Mar 29, 2009 | 05:30 PM
JLWelding's Avatar
Yea I must say there have been a lot of meeting of the minds on this I just wish something would break so I can say now I know what it is. I think I will buy new apps,just because it has so many miles on it and just see what that does, what can it hurt right.
Old Mar 29, 2009 | 08:58 PM
scottsjeeprolet's Avatar
Go RAVENS!!!!!!!!!
If your getting a new Apps then i would get the Timbo apps. I've heard nothing but good things about it.
Old Mar 29, 2009 | 09:14 PM
yankeeflatsdiesel's Avatar
have heard in the past on someone elses 24v that the it was the carnk posistion sensor causing something similar to your problem.
justinsbeck
Jan 18, 2016 12:15 AM
Dslmech600
Price Quote - Request A Price
Aug 11, 2015 09:39 AM
Big Bill
Mar 19, 2015 11:13 AM
DeLuzGN
Mar 17, 2015 08:08 AM
somarillw
Dec 15, 2014 12:00 AM
