Brand New AirDog
Old Mar 26, 2009 | 11:30 PM
BBD's Avatar
BBD
Default Brand New AirDog
Brand new AirDog 100 or 150 free shipping and LIFETIME WARRANTY for only $470.00 cheapest price anywhere
Most Compact System Available for the Pickup Truck.
Only 7” L x 3.2” W x 10” H
High Efficiency, Long Life Gerotor Fuel Pump
Lower Cost Replacement Filters
3, 5, and 10 Micron AirDog® Fuel Filters Available
Relay Controlled Wiring Harness
Low Fuel Pressure Warning Light Available
Includes Wire Screen Water Separator
Lifetime Waranty
90 Day Satisfaction Guarantee
The compact AirDog® provides the most effective technology designed specifically for diesel pickups to remove water, particulates, vapor and entrained air from diesel fuel. The AirDog® replaces the Cummins factory lift pump and filter system, and enhances the fuel delivery to the Powerstroke and Duramax with a commercial duty system.
Your High Performance diesel engine demands higher fuel flows. Yet, higher fuel flows increase the vacuum at the fuel pump and agitation in the fuel tank. These factors generate additional air/vapor in the fuel system preventing your engine from producing maximum power and efficiency. Additionally, air/vapor can cause galling and pitting of the injector barrel/plunger assembly and also tip erosion.
The AirDog® eliminates the air in the fuel that robs your engine of consistently greater performance and can also cause permanent damage to your injectors. The AirDog® also provides the fuel pressures and flows your diesel engine needs to produce maximum power, any time, every time!
For serious performance seekers, whether you run a Cummins Turbo Diesel, Duramax, or Powerstroke on the daily grind or for weekend pleasure, the AirDog® has something to offer you!
AirDog
BBD
Old Mar 26, 2009 | 11:43 PM
Red_Rattler's Avatar
High Tech Redneck
Have more than one I assume?
Old Mar 27, 2009 | 07:55 AM
BBD's Avatar
BBD
I have one brand new, in the box, with lifetime warranty.
BBD
Old Mar 27, 2009 | 04:56 PM
xzaq103's Avatar
FormerVendor
Old Mar 29, 2009 | 09:24 PM
BBD's Avatar
BBD
Originally Posted by xzaq103
PM sent back at ya
BBD
Old Apr 16, 2009 | 09:57 PM
BBD's Avatar
BBD
Bump, still have one brand new lifetime warranty.
BBD
acj
9
Dec 26, 2015 09:54 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
Jet A Fuel
Jun 5, 2015 03:28 PM
dirtymaxrens
Price Quote - Request A Price
Jan 24, 2015 08:02 PM
justinsbeck
Nov 21, 2014 11:53 AM
