plugging wastgate
Old Mar 26, 2009 | 10:26 PM
djwhonda92's Avatar
Exclamation plugging wastgate
I need to know how to plug my wastegate line? and what it will do to my performance? and if i install a BD performance elbow can it still be plugged or is that the same thing
Old Mar 26, 2009 | 10:30 PM
Red_Rattler's Avatar
High Tech Redneck
If you have a boost elbow on your turbo housing this will do what u want it to do. Its totally adjustable on psi and its cheap and I have one and love it! Adjustable Boost Elbow But I wouldn't totally disable the wastegate. Too much boost is not good for the turbo or motor. I wouldn't go any higher than 37 to 40 psi.
Old Mar 26, 2009 | 11:00 PM
392hemix's Avatar
Ya, what he said. but your not doing any good pushing a stock turbo over 35psi and i wouldnt feel comfertable pushing a stock hg over 30psi. but some people have and had no issues. its all up to you and how much money you have if you do have a head gasket fail.
Old Mar 26, 2009 | 11:37 PM
djwhonda92's Avatar
so do you know how to plug it though
Old Mar 26, 2009 | 11:41 PM
oglejust's Avatar
take the line off and put a bolt in it.....
Old Mar 26, 2009 | 11:47 PM
djwhonda92's Avatar
where is the line.? is it the one on the bottom of the turbo?
Old Mar 27, 2009 | 12:29 AM
94cummins12v's Avatar
yes
Old Mar 27, 2009 | 01:09 AM
djwhonda92's Avatar
we plugged the end that T's into the wastegate, is that right? cuz i felt no power gain possibly even a loss
Old Mar 27, 2009 | 07:30 AM
BAD ASS RAM's Avatar
make sure you have the one that goes from the "t" on the turbo to the wastegate.do you have a boost gauge?how many pounds are you pushing.you could have leaks in your system.http://https://www.dieselbombers.com...tructions.html
Old Mar 27, 2009 | 08:34 AM
djwhonda92's Avatar
ya it wouldn't suprise me if i was leaking because the line was very old and corroded... ya it was the right one, and i even checked it while running and when i unplugged it and hit the gas there was air spewing out the hole, so then i plugged it again and still notice no difference... no i dont have gauges
