Installed my 13cm Stainless Steel turbo Ex housing
Old Mar 26, 2009 | 07:50 PM
Rooster24v's Avatar
Default Installed my 13cm Stainless Steel turbo Ex housing
Well i installed it no problem. I have more boost now, with my adr on PL 4 i can hit about 30 psi of pressure and my EGTs are even lower than before.. and now my truck accelerates harder and my egts are lower just on level 4!, best of both worlds! Included with the housing was a new housing/manifold steel gasket and a different boost elbow, the elbow that was on my 12cm was about a 1/4" hole now the new one has a pin hole-hole but still wastegated for 42-45 psi. I called High Tech Turbo and talked to Jonas about why my boost has been higher with this 13cm compared to my 12, and he told me that this new housing is Stainless Steel and holds the heat in better that is helping getting your boost a little higher... also in turn it will keep your EGTs more in check. which is has. so if anyone is running a HTB2 62-14 check out the 13cm, or you can buy my 12cm from me!
Old Mar 27, 2009 | 03:28 AM
Glad you like it
|WYG|SS
Aug 7, 2015 04:52 AM
D-350 dually
Apr 11, 2015 11:38 PM
GreenDieselF
Oct 20, 2014 02:05 PM
