Sputtering on Hills
Old Mar 25, 2009 | 10:32 PM
cornelius's Avatar
Default Sputtering on Hills
When I'm cruisin with the cruise control on and I hit a hill the motor sputters on puffs a little bit of balck smoke. Im thinkin its the egr valve, I'v e never had it out or cleaned it. Just wondering if anybody has any ideas.
Old Mar 26, 2009 | 12:54 AM
jnicewan's Avatar
when you say sputters, do you mean a misfire, or bucking. the puff wouldnt bother me if its accelerating. but if a miss/buck too i would look into that. do you have access to a scanner/code reader to read dtc's if any. sometimes a DTC will set but not turn the ck eng lamp on. and it may have a pending code too.
Old Mar 26, 2009 | 01:16 AM
cornelius's Avatar
yeah its a misfire when it excelerates, bucking is the action that the truck makes. No I dont have access to a coder.
Old Mar 26, 2009 | 08:16 AM
hock6.0's Avatar
if you never had the egr valve out, i would definitly take it out and clean it. I clean mine every 4-5k cause it starts bucking.
Old Mar 26, 2009 | 10:32 PM
cornelius's Avatar
I'm going to pull that egr valve do the fuel filters again as well. Do they make aftermarket egr valves or do you have to go to ford for them, just in case I need to get a new one.
has anybody ever just unplugged the egr valve, I'm wondering if this will hurt anything. I read that it will just be in the closed position at all times.
Old Mar 27, 2009 | 07:01 AM
hock6.0's Avatar
you can get new ford egr valves off ebay starting at about $60. thats where i got the last one. othere than that everyone tells me to go to a ford dealer. Auto parts stores can't get them. They are about $330 from ford.
Old Mar 27, 2009 | 09:29 PM
cornelius's Avatar
I pulled that egr valve and cleaned it. The exhaust is blowin a little blew not to sur why that is. Just had the egr cooler change out. They said that the oil cooler was workin fine, same smoke when the motor is cold or hot.
Old Mar 27, 2009 | 10:20 PM
hock6.0's Avatar
Did cleaning the egr valve help any? when the o-rings get chewed up on your valve where it won't seal good you can buy a seal kit for it. it comes with both o-rings and the gasket for about $7. good way to save some money.
Old Mar 28, 2009 | 06:35 AM
cornelius's Avatar
have'nt had it out on the road yet, I'll test drive it today. can't figure out why its blowin smoke.
Old Mar 28, 2009 | 07:08 AM
hock6.0's Avatar
can't help with the blue smoke, mine blows blue smoke for 5-10 mins when i start it in the morning, after that it's all black smoke.
