will tires hold,not load rated
Old Mar 25, 2009 | 10:13 PM
will1am's Avatar
Default will tires hold,not load rated
just bought some tires for the 2500 94 2wd and they are not the load rated d or e.i think they are standard load but are a 114s wich is good for 2100 lbs
i am not going to haul anything over 1k lbs in the bed or tow anything over 4k lbs.
i have them set at 50psi...5 over recommended.
will i lose some feul milage due to less rolling resistance or are thes tires about the same
as an d or e rated load range tire
Old Mar 25, 2009 | 10:30 PM
Meralain's Avatar
From what I have read, the stiffer the sidewall and tread, the better the fuel mileage. Sounds like you got some 8 ply tires, the front tires might be a little under-rated carrying that Cummins around. I wouldn't be surprised if you fuel mileage didn't suffer considerably..... I have seen a difference of 2-3 mpg just from tread style on my '01. Right now I am running a set of "mastercraft" 10 ply tires with a M+S style tread, and seeing 22.1mpg hauling 750# of ballast in the box.
Old Mar 25, 2009 | 11:02 PM
94cummins12v's Avatar
i have a set of 315/75/16 cooper discover stt mud tires with a e rating 10ply tire and they do awsom in the snow, mud and towing, heavy loads
Old Mar 26, 2009 | 01:03 AM
jnicewan's Avatar
the load range is something alot of people dont consider when getting tires. but you said 2100lbs per tire. the only bad thing about that is your truck might weigh 6500-7500lbs empty. without knowing your truck and what extras you might have you could actually be sitting pretty darn close the max rated weight of the tires. you also never know if one day you might need to haul a trailer or heavy payload maybe not but what if you need to.
i have seen some heavily overloaded trucks and trailers on underated tires before. and not had problems. if it was mine i would want to get a tire thats overrated just in case. the higher the load rating almost always means they will last longer and take much more abuse to the tread and or sidewalls.
Old Mar 26, 2009 | 01:20 AM
Are these C or D load range?
I have been running 8 ply D range tires for awhile now - never had a problem but I rarely ever tow and am always empty.
Old Mar 26, 2009 | 11:13 AM
cumminsdad08's Avatar
gotta watch the lower tire ratings, we have a half ton 2wd at work with LR C's on it. it was fine for the longest time, pulled nice, hauled nice. but one by one, with the heavy loads on it, the tires started to bubble out on the inner walls, which is hard to take notice when you leave in the dark and get back in the dark. so i think it was the constant abuse that eventually wore them out early..... i guess what i think is, that if you don't do much with them, you will prolly be ok, but for the extra couple bucks i would go heavier, just my 2 cents
Old Mar 27, 2009 | 03:04 PM
will1am's Avatar
the front tires are load rated D...they are only rated at 2600 lb.the rears,new,are standard load and rated to 2200....i have the rears at 50psi too...which is over the max recommend for those tires.i am going to put the front tires at thier max which is 80psi.i have have the lightest 2nd gen truck you can get.(i beleive)i am going to watch my milage carefully now....i got 16mpg out of the last tankful
Old Mar 28, 2009 | 05:03 PM
colt45_usmc's Avatar
i was runnin 315 70 17 bighorn mudders and i pulled around on the average grossin 52k lbs and never had any trouble from the tires. the only trouble i had was from the auto tranny
bdemutis
Tire, Wheel & Suspension
Dec 28, 2016 07:35 PM
Jsully
Aug 31, 2015 07:55 PM
j_stroker
Mar 5, 2015 07:35 AM
ChgoSquad5
Ford Powerstroke 2011-Up 6.7L
Jan 6, 2015 11:37 PM
Nov 20, 2014 11:20 AM
