f250 2005
Old Mar 25, 2009 | 04:21 PM
slugo's Avatar
Default f250 2005
lost the brake lights and turn signals anyone tell me were the fuses are located or the relays
Old Mar 25, 2009 | 04:24 PM
BEERPLAY's Avatar
EITHER UNDER THE HOOD IN A BIGASS BLACK BOX OR INSIDE UNDER OR ON THE SIDE OF THE DASH I BELIEVE
Old Mar 25, 2009 | 04:31 PM
slugo's Avatar
Default fuse
I was hoping for a number off the fuse box
Old Mar 25, 2009 | 09:55 PM
jnicewan's Avatar
those bulb functions are on different fuse circuits.
F2.27 or just 27 in the fuse box under the dash does the flashers
f2.18 or just 18 same fuse box does the brake lamps.
go ahead and check the fuses, if both blown you probably have a shorted bulb or wire. if there good check to see if the high mount 3rd brake lamp is working. if it is you probably have a probem with the muti-function/turn signal switch. sometimes you can mess with the emergency flasher button moving up/down a few times and get the lights working again.
Old Mar 26, 2009 | 10:28 AM
slugo's Avatar
thank for your help it did the job
Old Mar 26, 2009 | 01:19 PM
jnicewan's Avatar
what was it
May 7, 2015 02:50 PM
alex74708
Dec 28, 2014 04:18 PM
bizurkhate
11
Nov 14, 2014 12:15 AM
fordjohn
Nov 10, 2014 08:07 AM
fordjohn
Nov 4, 2014 09:48 PM
