how much power
Old Mar 24, 2009 | 10:00 AM
BAD ASS RAM's Avatar
Talking how much power
i have a twelve valve with 100hp injectors,cold air intake,#0 fuel plate full foreward,afc slid full foreward,star wheel full foreward,and my waste gate disconnected.does anybody out there have a similar set up and know about how much horsepower/torque i should have?i was told like 315/700?and the most boost i can get is like 27 or 28 lbs.where would be a good place to start lookin for a leak?thans guys.
Old Mar 24, 2009 | 10:06 AM
stkdram55's Avatar
is your transmission built?? But the 315 is probably a good guess, ya lose alot of the power thru the auto and if its slippin your loosin more
Old Mar 24, 2009 | 10:32 AM
94cummins12v's Avatar
throw it on the rollers
Old Mar 24, 2009 | 10:33 AM
stkdram55's Avatar
your one to say that!!!
Old Mar 24, 2009 | 10:44 AM
yes my tranny is built,i don't know exactly what all is done but the guy that it is.it shifts like a race car(real hard).but my boost prob.they say stock turbo should put out 35lbs. and my peak is like 27-28.somebody told me to check for leaks where is a good place to start?or do i need to do something else?
Old Mar 24, 2009 | 10:46 AM
stkdram55's Avatar
intercooler boots is your most likely spot if there is a leak, they can get real small cut in em or the clamps can be loose. the gasket for the intake horn could be wiped out.
PS you should fill out your signature so we can see what ya have on your truck for your future questions....
Old Mar 24, 2009 | 11:17 AM
I JUST FILLED OUT MY SIGNATURE THAT'LL MAKE IT EASIER ON ME AND EVERYBODY ELSE.
Old Mar 24, 2009 | 11:20 AM
94 12valve's Avatar
if you don't find any bad boots the easyest way to find a boost leak is to build a boost leak tester
Old Mar 24, 2009 | 11:23 AM
HOW DO YOU BUILD A BOOST LEAK DETECTOR?AND WITH MY MODS SHOULD I NOT MAKE MORE BOOST THAN THAT?
Old Mar 24, 2009 | 12:06 PM
dieselmadscientist's Avatar
i took my wastegate off also and had a loss of power
