tool to remove injecectors?
Old Mar 23, 2009 | 10:16 PM
will1am's Avatar
Default tool to remove injecectors?
i think my injectors are leaking and not around the return manifold either.
i tried changing the banjo gasket and i still have leak on 5 of the injectors.
i might try changing switching out the leaking injector in place of non leaking one too
DO I NEED A SPECIAL TOOL to pull or install the injectors?
where can i get a good set of injectors too?
i really dont want to use more feul...i lookin at doing a cng setup
anybody ever order from pensecola diesel?
Old Mar 23, 2009 | 10:21 PM
392hemix's Avatar
you can get a good set of injectors form ddp, and they include a nut that bolts onto the injector that you pry on. they alos have great customer service. my injectors are leaking too, just like you explained, i think i am just going to get new injectors and i am going with the ddp 90hp. but they would use to much fuel for your case. but i think they have a more mild injector that will give you better fuel economy then stock injectors. look them up
Old Mar 23, 2009 | 10:50 PM
smokedout's Avatar
yeah I bought some injectors from pensecola and for $200 there pretty bad ***,and yes to get your old injectors out you need to buy a little piece of metal pipe that will fit over the injector and find a lug nut or a nut that threads on to the top of them and as you tighten the nut down it pulls the injector up using the motor as a base.Goog luck man and oh yeah get the 90hp there the same price as the rest. Have fun
Old Mar 23, 2009 | 10:52 PM
Whit's Avatar
Site Mascot
we have vendors with injectors and tools right here on site
Old Mar 23, 2009 | 10:53 PM
xzaq103's Avatar
FormerVendor
1/2" PVC pipe works as well just be careful threading the lug nut on.
As for Pensacola Diesel injectors.... Been there done that wont go back. Spend your money else where. there "stage 2" are a 300 or 330 4 Hole marine injeector so there 155* spray pattern is not correct for our engines.
Old Mar 23, 2009 | 11:07 PM
94cummins12v's Avatar
passing my method on i see
Old Mar 23, 2009 | 11:42 PM
Ask and ye shall receive:
Injector Puller for 12V engines
Old Mar 24, 2009 | 07:05 AM
Whit's Avatar
Site Mascot
Ifin I remember right the longer bolt off yer intake horn works for this
Old Mar 24, 2009 | 08:28 AM
will1am's Avatar
i think i understand all this
you put a cylinder around the injector and then use a bolt/nut to tighten on top of the injector over the cylinder wich makes the injecotr lift up.this is after i have loosened the injector out of the threads?
do ineed a special too to install the injectors as well?
Old Mar 24, 2009 | 10:29 AM
nope just put the new injector in and tighten the nut. the pipe/nut trick is the easyist to tackle
