Towing My Truck
Old Mar 23, 2009 | 07:21 PM
jrhbull74's Avatar
Default Towing My Truck
I have a 1999 Ram 3500 4X4 Diesel if i install a towbar on the front is it ok to tow this vehicle??
Old Mar 23, 2009 | 09:12 PM
RSWORDS's Avatar
I have not seen any tow bars that are rated for above 5,000 lbs. Your truck is probably pushing 8,000. If you get past that I'm not sure if you need to pull the drive shafts or just put everything (tranny, Transfer case) in N. Also you going to need one heck of a truck to pull it with for it not to push it all over the road.
Old Mar 23, 2009 | 09:31 PM
Red_Rattler's Avatar
High Tech Redneck
A local well company here flat tows there f350's and 450's behind their drill rigs with some heavy duty pintle style tow bars. Dunno if they drop the driveshafts or not but I doubt they do. But when my dad and I brought back my first truck from NC to WI we rented a uhaul dolly and dropped the rear driveshaft.
Old Mar 23, 2009 | 09:49 PM
spoolinaround's Avatar
I move plow trucks around with a heavy tow bar I built that slides in the plow mount, it is good for moving the trucks around without having to tow a trailer or have a helper, hell I tow my 3500 with a Mitsubishi-Fuso cabover, whatever you do make it strong, my bar is made from 3x3x½" angle iron with a pintle hitch.
Old Mar 24, 2009 | 01:37 AM
01quadcab's Avatar
if you get the right bar yes, but pull the drive shafts if your going more than 10 miles as the trans will not oil right overheat and cause all kinds of issues. It's much better to be safe than to have to replace a trans. For the rear pull it out of the rear end duct tape the u-joint on and tie it up under the truck as to not leak tranny fluid out the tailshaft if you have an auto..
Old Mar 24, 2009 | 05:20 AM
gwhammy's Avatar
On a 4x4 I think you can leave the transmission in park and put the transfer case in neutral. This will run the pump in the transfer case and stop any moving parts in the transmission. Check for sure but I think that's right. A tow bar out of 2 inch tubing ought to be heavy enough.
Old Mar 24, 2009 | 05:39 AM
Jazz's Avatar
I know when I had a jeep and flat towed behind my motorhome I always put the transfer case in neutral and trans. in park. As said above This will run the pump in the transfer case and stop any moving parts in the transmission.
Old Mar 24, 2009 | 08:52 AM
I always just put the transfer case in neutral, never had a problem, as long as the rear driveshaft is spinning it is pumping fluid through the case
JSATCT860
Towing and Hauling
Jun 15, 2015 11:21 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Oct 14, 2014 08:40 AM
