Fuel filter change/now no start
Old Mar 23, 2009 | 06:55 AM
Gringochad's Avatar
Default Fuel filter change/now no start
Yesterday my buddy calls me and says that he changed the fuel filter on his 06 Cummins and now it won't start. So I went over to lend a hand and we could not figure it out. The starter just clicks. Put some jumper cables on it and it just clicks louder. We removed the starter and had it tested, no problem there. Any ideas????
Old Mar 23, 2009 | 07:37 AM
wildbill's Avatar
Sounds like bad batteries. Swap yours out for his and see if that helps.
Old Mar 23, 2009 | 10:25 AM
MRaynor's Avatar
Either that, or he may have knocked one of the electrical plugs or a ground wire loose.
Old Mar 23, 2009 | 12:03 PM
cumminscr's Avatar
yea theres quite a few electrical wires on the fuel filter assembly, coulda possibly knocked one out while loosing/tighting the big 1 1/8 nut...
Old Mar 26, 2009 | 09:12 AM
MRaynor's Avatar
Did you figure out what it was yet?
Old Mar 26, 2009 | 04:18 PM
Lostnwalmart's Avatar
could be a dead spot in the starter try hitting it with a hammer when cranking when you took it to be tested it could have moved just enough off that dead spot to work and it will have enough momentum to skip it.
Old Mar 30, 2009 | 06:33 AM
Gringochad's Avatar
Yup, batteries just happened to kick the bucket the same time he changed his filter
jeffersonl
Nov 15, 2015 07:35 PM
Cavnar
Sep 9, 2015 07:18 PM
RatsMC
May 4, 2015 05:25 PM
Collin Dow
Feb 21, 2015 08:18 PM
moneypitk5
Feb 12, 2015 11:01 AM
