throttle
Old Mar 22, 2009 | 09:58 PM
dan33klein's Avatar
Default throttle
hey guys. once in a while for some reason my throttle gets stuck at ABOUT 1300 rpms and i cant get it back to an idle unless i pop the hood and manualy grab it and pull it back to an idle. then if i shut it off and come back out the next morning its good to go for about 4 days than it will do it again. any sugestions?
Old Mar 22, 2009 | 10:12 PM
94cummins12v's Avatar
i had that problem a year ago. there is a spring on the p-pump that returns the throttle back to the bottom its on the driver side rear of the pump. you can get a replacement at napa for aroung $5 has your throttle linkage been replaced under the dodge recal
Old Mar 23, 2009 | 03:51 PM
dan33klein's Avatar
ill look into that spring. im not sure when i got a carfax report when i bough the truck it showed were it had a recall. but idk if it was ever replaced
Old Mar 23, 2009 | 04:04 PM
There was a recall on the throttle cable...
http://dodgeram.info/tsb/recalls/970.htm
Old Mar 23, 2009 | 09:19 PM
dan33klein's Avatar
is there a way to know if mine has been changed?
Old Mar 23, 2009 | 10:12 PM
call dodge and give them the vin number and they will tell you every recal that has been taken care of
12vWoodHauler
Sep 30, 2015 07:58 PM
Blair@BD
BD-Power
Sep 10, 2015 12:29 PM
Jake202
Jun 21, 2015 09:42 PM
Jmohr52
Mar 4, 2015 01:18 AM
1stgenswap
Nov 3, 2014 09:45 PM
