Stock turbo
Old Mar 22, 2009 | 09:47 PM
redneck_cummins's Avatar
Default Stock turbo
Whats the max horsepower that the stock hx35w turbo support and whats the max boost you can run with these turbos before you have to have o-rings and head studs installed. Thanks for the help
Andrew
Old Mar 22, 2009 | 09:53 PM
BlackDodge's Avatar
X2
Old Mar 22, 2009 | 11:59 PM
bmoeller's Avatar
A guy I know made 388hp last summer on Dunbar's dyno. He makes 50 psi (with 13-1500+ EGTs) towing a big gooseneck with hay or equipment. But, just because he can, doesn't mean you should. He shouldn't either. Keeping a HX35 under 35 psi is the best for it.
Old Mar 23, 2009 | 12:02 AM
94cummins12v's Avatar
ok first i have herd a hx35 support 400hp, seocound call me when he hits 50psi again witha stock turbo so i can watch him pull compressor wheel fragments out of his intake pipes. a hx35 is worthless past 35psi and anything over is in the danger zone anyway. a stock headgasket shouldnt excede 45psi, a stock headgasket with studs can hit 60psi and o-ring with studs 85psi
Old Mar 23, 2009 | 12:10 AM
DB Admin's Avatar
Banned
Biggest miss conception of gauging a turbos ability is Boost Pressure , high numbers are bad on stock engines , you want more air flow and less pressure , your stock turbo is building pressure but its not alot of cool flowing air , when i went with the ATS intake and exhaust manifolds my boost pressure dropped tremendously , when i went with the s300 again my boost pressures dropped but its an entirely different truck , I went from a 60# gauge to a 35# gauge as im a single charger on stock head gasket and dont need to be pushing more than 35 psi to get the job done
Old Mar 23, 2009 | 12:15 AM
excaclty
Old Mar 23, 2009 | 12:38 AM
Thanks for the input guys. I was just wondering what the limits of the stocker was so I would know not to exceed it Ive yet to pass 25 pounds of boost. Dont really have the extra $$ laying around for a new if yall know what I mean
Andrew
Old Mar 23, 2009 | 12:44 AM
you can it 40 but its really no different that 35 except for the heat, you dont benifit from it, i have seen a stock wh1c and hx35 explode at 42psi before with average of 225,000 miles
Pushing over 35psi on a HX35 is creating very high drive pressures. This is what pops a HG.
Old Mar 23, 2009 | 12:46 AM
yep stock turbos are made for stock power and barely anymore
