4WD launch
Old Mar 22, 2009 | 09:41 PM
cdiesel217's Avatar
Default 4WD launch
ok, so I've never done a 4wd start before. after you start and get up to 30-40mph, do you shift back to 2wd mode? is it harder on the transmission? thanks guys.
Old Mar 22, 2009 | 10:19 PM
94cummins12v's Avatar
of course a 4x4 boosted launch is harder on the tranny your getting another axle spinning with more weight on it
Old Mar 22, 2009 | 10:36 PM
2500HeavyDuty's Avatar
ive always kept mine in 4wd when i go down the track, it is kinda hard to shift out of 4wd when ur wot
Old Mar 22, 2009 | 10:40 PM
thats why i got the 2low setup on my 12v so when im going down the strip i can flip the switch and it will disconect my hubs, it wont stock my t-case from spinning but it will reliese the drag and pressure of the front tires
thats a pretty slick set up
Old Mar 22, 2009 | 10:53 PM
just a pacbrake switch on a toggle that controlls the vacuum for the hub 4x4 actuator
Old Mar 23, 2009 | 09:46 AM
DslDeamon's Avatar
if its standard i just push the clutch in for a sec to release pressure and put it back in 2wd...."94cummins12v" has a nice setup tho to
Old Mar 23, 2009 | 11:35 PM
i think that would drop you time doing that
Old Mar 24, 2009 | 11:09 AM
yeah, rowing gears is bad enough for times
Old Mar 25, 2009 | 12:24 AM
that actuator switch i hav is just on a toggle switch, i have it set upso when im at the track i can mount it on my steering wheel for easy activation
Flikkie2001
12
Aug 29, 2015 10:03 PM
2gCummins
Jul 22, 2015 11:34 PM
mw1095mw
Jan 4, 2015 11:06 PM
lifted07sierra
Nov 24, 2014 10:22 PM
Oct 30, 2014 06:10 PM
