I like 'em stacked
Old Mar 22, 2009 | 04:38 PM
argve's Avatar
Default I like 'em stacked
Well I did some horse trading and got a hold of a single stack kit for cheap well I was told (haven't seen it yet) but all I'm getting is a stack, elbow and some clamps so how do you support the stack in the bed? I would like some pictures of some set ups so that I am mimic them with something from the shop...
Old Mar 22, 2009 | 04:59 PM
stkdram55's Avatar
you could get a staxxx clamp but they are kinda pricey, the way i did it was cut a 'u' in a 1/4 plate of steel and slid it around the pipe coming thru the bed...then i ran two carriage bolts down thru it and the bed. then i welded the pipe to to plate, it holds it good it shakes a little but it works
Old Apr 1, 2009 | 09:39 PM
bowtech's Avatar
i have a single stack and i just cut a peice of rectangle tubeing square on the side i weld to the stack and a angle cut on the other so you can run a bead along the edge of the pipe to weld it to the bed.
Old Apr 1, 2009 | 11:54 PM
djwhonda92's Avatar
i have a single stack and i just self tapped a screw into my stack and on the other end of the metal 90 degree joint i put another..into the bed
Old Apr 2, 2009 | 07:04 AM
Bosshogg's Avatar
The problem is you dont have the other stack!!! Its much easier to do it that way. Heres a pic of my buddy's truck but mine is identical. In fact, I made the box myself.
Old Apr 2, 2009 | 08:09 AM
Whit's Avatar
Site Mascot
Trav..............you got er in yet bud..........Pics man I wanna see the flapper
Old Apr 6, 2009 | 04:42 PM
392hemix's Avatar
I like the box idea, that looks cool and rugged. maybe i will do that toooooo ILIKE
Old Apr 6, 2009 | 05:43 PM
Bosshogg's Avatar
Got one layin down at dads I would sell you
4" inlet to dual 5" outlets. I think the outlets line up with the black strips on the cab, but dont quote me...
Old Apr 7, 2009 | 03:47 PM
HAYMAFIA's Avatar
if you use square tubing make sure that it is new. I used an old piece on a 6.5 lost a piece of rust into a load of hay and got a little excitement
