help with hood stack on 91 f250 7.3idi
Old Mar 21, 2009 | 08:24 PM
dirty diesels's Avatar
Default help with hood stack on 91 f250 7.3idi
i have a stock 91 f250 7.3idi i have the pump turned up 3 turns so it pours the smoke people told me that i should have put a pyrometer on it i dont know if that is true would like info on it if any next question how do i fab a stack coming out of hood is there a way i can o that and what will need to be done is there any place that sells kits for such things as that ?
Old Mar 23, 2009 | 01:18 AM
jnicewan's Avatar
idi's run hot at factory levels especially non turbos, they can get to scary temps with just a 1/4 turn on the pump. if you have a bunch of black smoke you damn sure need a pyro.
hood stacks are not impossible i would imagine a talented exhaust shop could do it. but if you look there is next to nothing for room around the manifold area either side. i have only seen that done on cummins puller trucks. but they have all kinds of room and only one exh outlet.
Old Mar 23, 2009 | 03:21 AM
LOGANSTANFORTH's Avatar
if you want the truck to live you might as well back the pump off, especially since its naturally aspirated......it IS going to melt.....PERIOD....
Old Mar 25, 2009 | 03:38 PM
92hyperdiesel's Avatar
Get you a hypermax turbo or banks turbo turn the injection pump down to stock and then a slight adjust meant
also you need to adjust your timing and retard it slightly
Last edited by 92hyperdiesel; Mar 25, 2009 at 03:38 PM. Reason: Automerged Doublepost
Old Mar 25, 2009 | 10:46 PM
jnicewan's Avatar
or an ats turbo, i think banks is done making stuff for the idi's. the ats kit is who ford used to make all the factory turbo idi's in 93-94 btw.
retarding timing is going to sap the much needed power from idi's.
Old Mar 26, 2009 | 08:13 AM
i was told if you turn the injection pump up you need to slightly retard it not enough to evn really effect if just the all the more fuel is there when the sylinder fires off? Maybe i heard wrong ? no trying to miss lead anyone?
Old Mar 26, 2009 | 09:02 PM
spoolinaround's Avatar
3 turns, OMG thats nuts, I bet if you get in it and stay in it for 30 seconds she will melt down, with a half turn on my old 7.3 idi truck she would go 1400 real fast
Old Apr 2, 2009 | 08:23 AM
my thoughts exactly 3 turns sounds very dangerous
Old Apr 9, 2009 | 12:57 AM
FarmDiesel's Avatar
Dual hood stacks? Just off the top of my head that seems eaiser then a single on this specific vehicle
Old Apr 23, 2009 | 05:12 AM
93 Indirect Injected's Avatar
dual hood stacks would be beast, and yes go for the ATS, i love mine, and he's right about the ford factory turbos
