fuel lope?
Old Mar 21, 2009 | 05:44 PM
cumminsCrazy's Avatar
Default fuel lope?
okay so i got these nozzles stage 5 and there pop tested to cummins spec... and it has a lope every once in a while at idle i made sure they were pop tested but could it be anything else?
Old Mar 21, 2009 | 05:46 PM
stkdram55's Avatar
my brothers truck does the same thing, someone on here said to check the crossover tubes to make sure there seated good
Old Mar 21, 2009 | 05:53 PM
okay ill look at that it just bugs me when its loping makes the truck sound like a POS
Old Mar 21, 2009 | 08:11 PM
Hows your fuel pressure?
Old Mar 22, 2009 | 01:39 AM
idle 20PSI and WOT 13PSI
Old Mar 22, 2009 | 10:13 AM
Mopar1973Man's Avatar
I heard that some large injectors or cross over tubes can and will cause a lopey idle...
Old Mar 22, 2009 | 10:21 AM
okay thanks i was just wonderin maybe a bigger turbo might make it smooth out?
Old Mar 22, 2009 | 08:22 PM
stumpy's Avatar
my truck does the same thing,i got 150 hp nozzles and after its has been run and i let it idle it will start loping. about a week ago i changed my air filter and it didnt do it for two days and then it started doing it again
Old Mar 22, 2009 | 09:52 PM
BlackDodge's Avatar
So you guys are saying when i put my 150 sticks in , i should expect it to lope???
Old Mar 22, 2009 | 09:54 PM
IDK if you should expect it but i might bo it...
