C.R. turbo an upgrade for 1st gen?
Old Mar 21, 2009 | 01:52 PM
wyoranch's Avatar
Default C.R. turbo an upgrade for 1st gen?
Hey guys, ive got an '03 S.O. and a '92. Been thinkin about upgrading my charger on the '03 and was wondering if the turbo would fit on my '92. I know its positioned differently so the exhaust and intercooler piping would need to be changed. Would this be a good upgrade for the '92?
Old Mar 21, 2009 | 01:54 PM
stkdram55's Avatar
the 03's i believe have electronic waste gates and that would be the only downfall to doing the swap, if it stayed closed it wouldnt be a problem you would just have to watch your boost guage
Old Mar 21, 2009 | 03:31 PM
RSWORDS's Avatar
I've read about some people trying it. From what I gather it is a OK upgrade for a stockish truck. I'll dee if I can find anything else out on it.
Old Mar 21, 2009 | 03:44 PM
Red_Rattler's Avatar
High Tech Redneck
03-04 are still mechanically wastegated. 04.5 and up are electronic....
Old Mar 22, 2009 | 02:06 PM
RSWORDS's Avatar
The 03 CR turbo is a HE341 and is a 54/58/9 turbo.
The 04.5 and up is a HE351 and measures 60/60/9
I think the turbo has 2 studs on the top that you will have to drill out the holes on teh manifold to mount it.
it should be good to support 350 HP on a 1st gen. Not a whole lot of info out there. The exhaust might get a tad tricky on you also. The best thing I can tell you is go pop the hood on your truck. Set teh 3rd gen turbo on the valve covers and stare at it for a while. Think about all the possible issues you can run into. If it looks like it should work do it! ou can always go back to stock!!!
Old Apr 4, 2009 | 12:27 PM
The_Head's Avatar
I'm running the HE341 now. It's not bad. Spool up is excellent, EGT's are manageable. I was towing my 5000 lb fifth wheel camper to Billings on a flat surface at 70 and was at 800* (preturbo), which I think is decent. I may of had a tailwind though... I have gotten toasty (1350*) hauling same trailer up an extended 6% grade, but I had it in OD by accident.
It whistles a little less than a H1C with the 60 mm compressor upgrade.
If you have a totally stock turbo and can do your own fab work, AND don't want to make past 300-350 whp, this turbo would be a good choice, IMO.
There is not much demand for them, so they are pretty cheap. I got mine for $225 shipped. If you upgrade the H1C, you're going to spend almost that much on the compressor upgrade alone, and then you would still be stuck with a 18.5 or 21 cm exhaust housing.
Hope that helps.
Old Apr 4, 2009 | 12:33 PM
wyoranch's Avatar
Thanks yall. I appreciate the info
Old Apr 4, 2009 | 01:45 PM
The_Head's Avatar
A guy on DTR did a HE351 swap. he removed the electronic wastegate and closed off the hole.
Old Jul 5, 2009 | 10:32 PM
D Gandy's Avatar
Would this be a good turbo to use with a twin setup on 1st gen.?(he351) If so what would be a good big turbo to use with it for 450-500 and possibly later 14mm head and cam plate?
Old Jul 9, 2009 | 08:17 PM
Riflemanusmc's Avatar
Yes they use the HE351 for twins on 3rd GEN's. No reason not to use it on a 1st GEN. The 3rd GEN owners have made well over 500hp with just the HE351. Would like to see what it would do as a set of twins with a 475 on the bottom. If both would do 600/650 on fuel, that would be great. Lloyd Mills and I were talking late last year about twin piping. He said he had a company that was doing mandrel bent kits for $1200 out the door. Thats cheap. Not everyone can/has the talent to do their own piping. When I replaced my HE341 on my 04 to a HE351, I zip tied the waste gate hose shut. 42psi max boost. 600deg on the hiway at 78mph. Never got over 1100deg. Fueled with a Smarty on REVO. No smoke unless I wanted to dog it, then it would black out the sun. Not much point in that. Clean burning setup... Hope this helps you...
