ve pump question
Old Mar 21, 2009 | 09:15 AM
cumminskid92's Avatar
Default ve pump question
can anyone tell me what the three wires on the side and back of my pump are for and what would happen if they came unplugged.
Old Mar 21, 2009 | 03:37 PM
RSWORDS's Avatar
One is the shut off valve. If you undo it the truck wont shut off. One is the KSB switch, it advances the timing when the truck is cold. And one is... Dang I'll have to go look...
I can get you a picture up in a little while...
Old Mar 22, 2009 | 02:02 PM
alright if you can get that pic that would be great. thanks
Old Mar 22, 2009 | 09:36 PM
RSWORDS's Avatar
Non-Intercooled Wires
A: Grid heater ground
B: Air temp sensor
C: Engine ground
D: Grid heater power
E: Oil pressure sender
F: Water in fuel (WIF) light sensor
G: Shutoff solenoid
H: KSB solenoid
I: Main bulkhead connector
J: Low vacuum warning sensor
K: Starter relay
L & M: Grid heater relays
N: Brain box (runs grid heaters, WIF light, and KSB)
Old Mar 22, 2009 | 09:37 PM
RSWORDS's Avatar
The other wire on your pump should be the TPS
Old Mar 23, 2009 | 12:07 AM
94cummins12v's Avatar
damn there aint much to them damn things for wires, i thought my 94 12v was bare
landon025
Sep 8, 2015 09:21 PM
PA 24valve
Aug 31, 2015 06:08 AM
HardLuck
Jun 24, 2015 08:04 AM
ItsAChummins
May 15, 2015 05:02 PM
CJJD4640
9
Feb 9, 2015 07:22 AM
