Duramax Trouble Code Requests
Old Jun 1, 2007 | 06:10 PM
rolloffhill's Avatar
Default Duramax Trouble Code Requests
If you have any questions as to what trouble code you are having with your Duramax, post the code here and we will be glad to let you know what it is and help you decide what can be done to fix it if applicable.
Old Jun 1, 2007 | 06:12 PM
THE most common code that will be brought up is
P1093 ~ Fuel Rail Pressure Low During Power Enrichment
Old Jun 1, 2007 | 09:16 PM
GmcLbz's Avatar
Site Sponsor - Upstate Diesel Performance
Default Duramax Codes
I keep getting the P0402 and just got the P2610. The P0402, is either a bad finger stick(Kennedy Diesel) or maybe a bad egr valve. The P2610 has to do with the ecm and I haven't got that one figured out yet.
Old Jun 2, 2007 | 07:22 AM
P0402 ~ Exhaust Gas Recirculation (EGR) Flow Excessive
P2610 ~ Control Module Ignition Off Timer Performance
DTC P2610 can be set with a loss of battery voltage to the ECM with the ignition ON. The ignition must be in the OFF position before disconnecting the ECM.
If P2610 is set, turn the ignition OFF and then completely disconnect the ECM harness connector from the ECM for approximately 1 minute. Reinstall all of the ECM connectors and then attempt to clear codes with the scan tool.
⇒ If P2610 resets after code clear, replace the ECM
Can you reset your codes? If you can try that and see if the P0402 comes back, otherwise get ahold of John and see about getting the fingerstick replaced.
Old Jun 3, 2007 | 08:00 AM
GmcLbz's Avatar
I cleared the P0402 and it came back, with no CEL.
I also cleared the P2610, I haven't checked to see if it came back yet.
Old Jun 3, 2007 | 02:10 PM
dozerboy's Avatar
Did you solder the connections of the FS if not you might redo it and see if that is the problem?
Old Jun 3, 2007 | 03:33 PM
GmcLbz's Avatar
Default Finger Stick
Yeah I did take the time to solder the connections. I couldn't see cobbing together a $40k truck.
Old Nov 15, 2007 | 06:16 PM
DB Admin's Avatar
Banned
https://www.dieselbombers.com/codes.php
Old Nov 16, 2007 | 07:18 PM
2500HeavyDuty's Avatar
Originally Posted by DieselMinded
sweet never knew that was there
Old Nov 29, 2007 | 02:16 AM
coldLBZ's Avatar
These are the 2006 LBZ block heater codes in case anyone is interested.
PO116 (coolant temp)
PO181 (fuel temp)
PO700 (trans requested malfuction indicator lamp)
When I got these my CEL would be on steady, I had no cruise control, and the truck wouldn't shift until about 2300 RPM or so. Hope this helps.
