water/meth injection
does anyone know how hard it is to install a water/meth kit. i live in an apartment and my landlords gets onto me for working in the parking lot. is it like a whole day job
Never done that or seen anobdy install one before. What kind are you getting?
finding a place to mount the pump and the tank and controller would be kinds the hardest to do in a parking lot. Then maybe its a few wires and hoses to set it up
Mine has been a semi-constant process over the last six months.
The basic kits involve removing mainfold, drilling and tapping the manifold, reinstalling the manifold, installing a pump, installing a controller, installing the controller sensors if it comes with them, installing a reservoir, and then wiring and plumbing it all together.
he could remove the intake air heater and install plug in it with a tap in there. i have a plug that fits in place of the intake air heater that needs tapping laying around.
some people even install a SD manifold it comes with a few taps built in so i can run anything you want in it.
i decided to hold off on the water/meth. im wanting to definitely do some twin turbos if not just a larger one.i dont want to add water/meth because i dont want to throw too much HP and start bending rods.
I installed a system on my truck and it took about 3 hours. It didn't have a controller, just an on/off switch to put in cab and is activated by a pressure switch which I have set at 20 psi. seems to work great especially when I tow a trailer.
