Ford Truck and Powerstroke Turbo Diesel Forum Discussion of General Topics related to All Ford Trucks as well as the Diesels in them
Ford's Scorpion Diesel
Old Mar 17, 2009 | 02:44 PM
MRaynor's Avatar
Smile Ford's Scorpion Diesel
Sources say Ford continues to make good progress testing its upcoming in-house-designed 6.7-liter V-8 diesel engine. The new engine will replace the Navistar-sourced 6.4-liter V-8 Power Stroke diesel engine in Ford's heavy-duty pickups by 2011. Code-named Scorpion, the new motor is said to pack plenty of sting -- plus a few other surprises.
The latest power targets are said to be more than 390 horsepower and 720 pounds-feet of torque. Today's Power Stroke diesel is rated at 350 hp and 650 pounds-feet.
Scorpion fuel economy is expected to improve by 3 mpg or more compared to the current Power Stroke. Helping the Scorpion's mileage will be a new six-speed automatic transmission, like the 2009 Ford F-150 will have.
The Scorpion is said to share several key traits with GM's revolutionary new 4.5-liter Duramax V-8 diesel engine. Intake and exhaust flow through the cylinder heads is reversed (relative to conventional diesel engine design) with the exhaust exiting directly into dual sequential turbos sitting in the engine's valley. The Scorpion will also use lighter aluminum cylinder heads, abandoning the cast-iron heads found in today's 6.4-liter Power Stroke.
Unlike the Duramax, the Scorpion diesel will continue to use an overhead valve engine design, rather than overhead cam.
The new 6.7-liter diesel engine will be manufactured in Mexico.
How important is this motor? The move is expected to permanently end Ford's longtime use of Navistar-built diesel engines in its heavy-duty pickups, due to an ongoing legal battle between the two companies over warranty and cost issues related to the old 6.0-liter V-8 Power Stroke (model years 2003-07). Ford has used Navistar diesels in its F-Series trucks since 1982.
It's not yet known if the Scorpion will continue to use the Power Stroke name or if Ford will create a brand new label for the engine. Whatever it's called, Ford's competitors are sure to feel the Scorpion's sting!
Source: Pickuptrucks.com
Old Mar 17, 2009 | 02:48 PM
Red_Rattler's Avatar
High Tech Redneck
Welcome to 2008
Scorpion Diesel
Good bump for the newbs though
Old Mar 17, 2009 | 02:56 PM
MRaynor's Avatar
Old Mar 17, 2009 | 08:33 PM
Woody35's Avatar
i was thinking i rememember reading this. hope it works out
Old Mar 18, 2009 | 07:38 AM
hock6.0's Avatar
i hope it's a good engine, but i was really hopen they would pair up with cummins or cat for the new diesel.
Old Mar 18, 2009 | 07:42 AM
wildbill's Avatar
They did get close to Cummins.....a 6.7L engine.
Old Mar 18, 2009 | 09:12 AM
LOGANSTANFORTH's Avatar
ford has a good reputation in building diesel engines......there heavy trucks used them for several years......if they are good engines i would buy one.....
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Mar 18, 2015 07:30 PM
Nov 28, 2014 09:50 PM
wolfnexus
Nov 4, 2014 10:04 PM
