luk clutch?
Old Mar 17, 2009 | 09:26 AM
banshe350's Avatar
Default luk clutch?
i am looking at a luk clutch on cumminsforum. im thinking its probably not the best becuase he only wants 200 for it? Its a ceramic clutch i guess. my truck is a 96 and I have pump mods, boost elbow, open intake and exhaust. not idea what im putting down for hp but it runs pretty good and I want a clutch that I can put in and not worry about. Im thinking probably a DD clutch? I do alot of towing and just playing around with it. Ive never hooked it to a sled or run it down a drag strip and dont really have any plans to right away.
anyways give me some price quotes...my stocker doesnt seem to like the new found power.
Old Mar 17, 2009 | 10:29 AM
94cummins12v's Avatar
you dont need a dual disk with the mods you have currently, but if your going higher i would, i would either go with a valair or a south bend on a cumming, the saying "you get what you pay for" stands true with clutches
Old Mar 17, 2009 | 11:37 AM
banshe350's Avatar
thats what i figured as far as getting what you pay for. I think I might just go with a dual disk just so i dont have to worry about it for a while. I plan on doing a turbo upgrade and some mild injectors but thats it.
Old Mar 17, 2009 | 11:39 AM
stkdram55's Avatar
yeah go with a southbend or valair DD clutch, that way you dont have to worry about it no more and can do what ever you want to do to the engine
Old Mar 17, 2009 | 12:25 PM
Old Mar 17, 2009 | 02:26 PM
12valvetater's Avatar
a big single disk will hold for a long time with what you have and what you do and use can use the money you saved on a DD/input shaft for other things
Old Mar 17, 2009 | 02:33 PM
banshe350's Avatar
ive heard of upgrading to a bigger input shaft or somthing? what will that gain me? whats the price diffrence between DD and a single that would work best for me?
Old Mar 17, 2009 | 09:45 PM
Beets's Avatar
i just installed the south bend 3600 plate load dutal dual disc, it not rated for compition use, but i wanted to go over kill, i paid about $1400 with taxes, so far i love the clutch, 100x better then the single i was running before. also i stayed with the 1.25 input shaft, plan on going with an iron giant down the road when money prevails and when i start pulling. the main advantage of the bigger 1.375 input shaft is strength, also i was told that the smaller input shaft does not have long enough splines but dont see that to be true.
Old Mar 17, 2009 | 11:10 PM
I'm running the Full Ceramic Clutch on my truck. I really like it but its really to grabby to be a towing clutch. If you have the $$$ available I would get a Valair DD. If money is tight we can set you up with a very nice Valair Single Disc.
Luke
Old Mar 17, 2009 | 11:21 PM
ajoebob's Avatar
i have a southbend single disk on mine. its rated at 550hp. it was graby at fristbut got smoother after it got broke in
