rotted oil pan
Old Mar 16, 2009 | 08:29 PM
bobbach's Avatar
Default rotted oil pan
I am about to replace the oil pan on my 2000 7.3 also while I am doing that I am replacing the rear main seal.I plan on an all day project, any tips from anyone would be appreciated before I start. thanks
Old Mar 16, 2009 | 09:46 PM
Cummins97's Avatar
Don't know much about fords, but
Old Mar 16, 2009 | 11:08 PM
stkdram55's Avatar
get lots of hand cleaner!!
Old Mar 16, 2009 | 11:28 PM
Red_Rattler's Avatar
High Tech Redneck
So you know you have to pull the motor to do that right? Which also requires removing the cab... Good luck bud!
Old Mar 17, 2009 | 02:03 AM
wildbill's Avatar
Old Mar 17, 2009 | 11:25 AM
DIESELDENT's Avatar
Old Mar 17, 2009 | 03:35 PM
Nitelord's Avatar
Enjoy the site..
Old Mar 17, 2009 | 11:28 PM
01quadcab's Avatar
best of luck on the fix too
Old Mar 18, 2009 | 03:09 AM
97cummins's Avatar
Old Mar 18, 2009 | 09:27 AM
Blue01F250's Avatar
Duramax Virgin
Yes - you have to pull the engine - NO - you don't have to remove the cab (its a 7.3, not 6.0)
also... why replace the RMS? They are usually, say 99%, never bad... likely a leak on the top of the engine at the turbo or hpop o-rings, or possibly even the dip stick tube... fills up the valley and then runs down the back of the engine, appearing to be a rear main seal leak.
Hope this helps - sounds like a heckuva project!
