Airdog/Fass 150 install tips?
Old Mar 16, 2009 | 07:57 PM
Rooster24v's Avatar
Default Airdog/Fass 150 install tips?
We are gong to be installing an Airdog 150 here tomorrow on my 98.5. Any tips to help install?
Old Mar 16, 2009 | 08:01 PM
Try to get your tank down to under 1/4 a tank. Double check all your fittings to make sure you got them tight. Don't forget to crack open an injector line or 2 to bleed the system.
Luke
Old Mar 16, 2009 | 08:07 PM
outlaw1_gt's Avatar
easy if follow directions i did mine by myself in my yard. hardest part was getting tank back in by myself but seen a post on here to use rachet straps to rachet it back up and was a breeze. i didnt have to crack any injector lines.
Old Mar 16, 2009 | 08:24 PM
busta's Avatar
take your time and ensure all the fittings are fully on so no air leaks
look up some of the mods for the fuel cannisters instead of drilling into tank
take your time and follow directions all will be well
Old Mar 16, 2009 | 08:49 PM
SeaDrive's Avatar
Hot water don't work on the pushlok fittings, use a heat gun (if it is cold a torpedo heater works well too). If you don't have one, have some grease on hand to get them on tight (up to the collar).
Old Mar 16, 2009 | 11:58 PM
Fishin2Deep4U's Avatar
We throw out the factory push lok fittings and replace all of them with AN adapters with swivel pushloks. We also use our own fuel hose.
Boiling water in a cup will soften the hose, but not as much as the heat gun as mentioned. Be careful to not overheat the ends as they will delaminate.
You only need to get over 2 barbs. If the fitting has 3, don't sweat that 3rd one. Te collar is just for decoration, it serves no useful purpose.
Crack the fuel line at the pump and bump it over. Snug when you get the air out.
Dave
Old Mar 17, 2009 | 10:15 AM
Rooster24v's Avatar
guys thanks for the tips! were going to be using a buddy's Injection shop so luckily we will be inside.. Did anyone put rubber grommets between the airdog bracket and the frame of the truck? i have heard they vibrate and make some noise?
JesseJames288
Jun 4, 2015 06:35 AM
2ndcummins1
Mar 9, 2015 10:01 AM
